rufunky
Pulling my weight
- Dec 2, 2015
- 707
- 248
@EMPIRETECANDY are these NTSC? The description on your site says pal.
its worth every dollar of $170, as soon as I can get my hands on the bullet version of this with external audio and alarm IO I have 2 4MP Dahuas that will be replaced after only a few months.![]()
This is a good case to not use a POE NVR. Get a standard NVR, separate switch, and separate POE injector. Might be a bit more money up front, but it makes accessing the cams directly much easier AND if any part goes bad, you only have to replace that bit, not the whole NVR. Three different devices isn't ideal for everyone, but something to think about.In regards to the Starlight and using a POE NVR...
either of the above would work -^ I have a 24 port non-poe with injector, so dont have my own recommendation for a poe switch...Just consider that you may one day want more cameras, so think carefully before going with only 8 ports. This is what I bought: Amazon.com: Cisco SF300-24 24-Port 10/100 Managed Switch with Gigabit Uplinks (SRW224G4-K9-NA): ElectronicsCare to recommend a switch for this? I would "prefer" 8 port with 2 ethernet uplink ports (not SFP for the uplink). I'm doing some searching, but thought you might already have a recommendation.
Of course, I guess I could simply go with a 16 port, and have some 'extra' ports on the switch for other uses.![]()
Is Dahua NVR 5216 the recommended one to go with 3 of these cameras?
Or what's another good NVR with PoE?
Maybe oversized for three cams, but well prepared for future constellations
There are also the NVR4xxx models. They are also available with PoE. Depends on your needs. If you guess one HDD is enough you could go with a NVR41xx-4KS2. But of course you'll have to look for yourself which one fits best for you. I would always recommend the -4KS2 models because of their capability for H.265 and 4K support if needed.
1HDD Models with PoE
NVR4104-P-4KS2: 4 channel, 4 PoE
NVR4108-P-4KS2: 8 channel, 4 PoE
NVR4108-8P-4KS2: 8 channel, 8 PoE
NVR4116-8P-4KS2: 16 channel, 8 PoE
2HDD models with PoE
NVR42xx
NVR52xx etc.
I don't want to list every model. As you can see you, the naming of the model gives your every info needed for initial choice, then you can look after the details.
NVR4xxx number is type of class, 6,7 are Ultra, 5 Pro, 4,2 are Lite
NVRx1xx number is amount of HDD
NVRxx16 number is amount of channels
-P is four port of PoE, -8P is eight ports of PoE and -16P is sixteen ports of PoE
Thank you! Will the NVR41xx models still give me all of the same cameras features that the NVR52xx would give me?
I really only need 4-8 channels.
Will these NVR's allow me to view the cameras on PC desktop internet explorer? Or is a switch required for that?
If you plan on using Motion Detection or IVS with your cameras, definitely read up on the threads about how the Dahua NVRs handle this. The NVR makes separate recordings for these clips (which isn't a bad thing), but the way it currently does this, many people are seeing 1-2 seconds of skipped (or black) video/audio at the beginning of these clips.Is Dahua NVR 5216 the recommended one to go with 3 of these cameras?
@aristobrat maybe I found a workaround to this. I'm still using the firmware from 2016-07 and tried to make the NVR not to do a second clip if an IVS event occurs. You remembered me to have a look at my footage to see if it works.If you plan on using Motion Detection or IVS with your cameras, definitely read up on the threads about how the Dahua NVRs handle this. The NVR makes separate recordings for these clips (which isn't a bad thing), but the way it currently does this, many people are seeing 1-2 seconds of skipped (or black) video/audio at the beginning of these clips.
Because of this, I've recently setup a PC running Blue Iris as a second NVR and it's working great. While Andy has been working with Dahua support regarding the issue above, there's been no progress, and at this point I wish I had never gone with the Dahua NVR.
You can manage the NVR (including viewing the cameras) from your PC by connecting via the NVR's web interface with IE. Or you can download a free program from Dahua called SmartPSS... that'll connect to your NVR and also let you manage it/view camera video.
If you get a NVR with POE built in, the NVR will create a separate network for your IP cameras. This can make it tricky to connect directly from your PC directly to the camera. You probably won't have a need to do that often once they're setup, but you'll probably need to do it frequently while you're getting things configured and tweaked properly.
