mat200
- Jan 17, 2017
- 19,541
- 32,609
Can this be mounted flat against a horizontal wall, or do you need to buy the additional wall mount? Doesnt seem like Andy is stocking the mount.
Hi Caveman,
Sometimes Andy does seem to have the mounts / junction boxes. Do contact him directly and check.
A PoE camera has about 16-18" of cable to the end of the connector
Options:
a) Mount directly on wall - drill 3/4" hole - connect cat5e/cat6 within the wall or attic ( or you can use plumbers tape and leave the connection section under the roof overhang if you have one )
or
b) Use a junction box or wall mount ( over hanging box ) to mount the camera ( for HDWxxR-Z series - PFA137, PFB203W )
For Junction box you can mount it directly on the wall - making a smaller hole for the cat5e/cat6 cable in the wall OR use a conduit
Connect the cables within the junction box.
So, in many cases the junction box is nice if you do not have a good way to easily connect the cables without leaving them exposed to the elements OR if you need to drill smaller holes through your walls. ( example if you have a brick or concrete building. )
Note the junction boxes / wall mount do give you a slight stand off from the wall, which maybe useful.
( example - I have a location which I would like to place the box and need some standoff to clear the gutter drain pipe )
Also, IF you purchase junction boxes / wall mounts and find that you have surplus after installing there is a classified section here - and these products work with a number of dahua cameras which have the same form factor.
[ note: If Andy is out of stock: I've had good luck when I purchased from Jimbu on Aliexpress - if you purchase enough from them they will DHL the shipment, and in my case they were fast. ]
