Since the bullet has 4 IRs versus 2 in the turret, would you say the performance is better for the bullet in very low lit areas? In your videos, performance looks nearly identical.
Got my camera today and am totally stumped. I know i have to be doing something wrong. My NVR is Laview LV-KN988p84A4 192.168.254.x are all the cameras. I can hook the camera up to a computer and access the config that way . but am unable to get it to show up on my nvr. I have tried to set the ip address to one of the open ip's on my nvr but it get an error saying "iP address and default gateway are not in the same network segment!" . For the life of me i can't figure out what i am missing. Any ideas?
Sometimes the simplest response is the obvious answer. Thank you . This was exactly what the problem was. I was changing the ip and not also changing the gateway ip to be in the same range.you need a gateway on 192.168.254.X
Did I enable IVS in SmartPlan? NO! With it enabled the rule lines show up. Doesn't solve the other problems.the latest firmware is in the first post, and they all work for me.. Did you enable the IVS in SmartPlan?
On the firmware, I saw the shipped version in the first post and didn't notice the link for the upgrade. I'm hesitating, however, because the upgrade link says it's for PAL and my camera is NTSC with no option to change it. I can't decide if it doesn't matter or I'd be taking a stupid risk to try it.
I believe the cameras check to make sure you are loading the right stuffMy concern is if loading PAL-specific firmware on an NTSC camera will produce a brick. I don't care which it is in the end, just that it works.
