T treb n3wb Apr 2, 2021 1 0 france Apr 2, 2021 #1 Hi all, I was trying to format the Dahua nvr via smartpss, logged in via admin account, when I select format hdd it comes up with a fault message: "Failed to save local storage information" Any suggestions how to format the drive ? Thank you!
iTuneDVR Pulling my weight Aug 23, 2014 885 163 Россия Apr 4, 2021 #2 If your hard is broken? Try to do this at NVR. More over put usb flash to you nvr & reboot it. After load your nvr at your usb flash possible txt log file. Smart send only command, so if any problem it at your nvr with your hdd.
