fenderman
Staff member
- Mar 9, 2014
- 36,883
- 21,419
some features like IVS are not available when using smart codec.My firmware doesnt have half the tabs and options as others with the same dahua cameras.. cant understand why
I don have smart codec on thosome features like IVS are not available when using smart codec.
So blue iris records fairly smooth with auto tracking but the live is choppy as shit.. i cant get this camera to display video smoothly..i have the resolution down to 720p 1024 bit rate and played with frame rates.. i cant get a good combination.. what am i doing wrongsome features like IVS are not available when using smart codec.
If I recall correctly, the max/min size target area setting will affect that.
how is your network setup? are the camera and pc connected to the router or are you using a switch?So blue iris records fairly smooth with auto tracking but the live is choppy as shit.. i cant get this camera to display video smoothly..i have the resolution down to 720p 1024 bit rate and played with frame rates.. i cant get a good combination.. what am i doing wrong
I have a verizon dsl modem router combo.. could this be the problem that it cant handle this camera?
Cameras straight to router and router straight to pchow is your network setup? are the camera and pc connected to the router or are you using a switch?
that is very possible...connect the camera and pc to a switch..also post your camera video and BI settings.Cameras straight to router and router straight to pc
I have 2 dome ptz cameras can you point me to what i need? Im soon to be getting a new good router.. would that help or do i need this switch? What does the switch do? Thanksthat is very possible...connect the camera and pc to a switch..also post your camera video and BI settings.
It plays choppy in the dahua firmware ie browser too..that is very possible...connect the camera and pc to a switch..also post your camera video and BI settings.
it could be the router, it could be bad cable or crimps...did you make your own cable? did you use the 568B wiring standard?It plays choppy in the dahua firmware ie browser too..
I have tried a couple different cat5 cables..a recording in blue iris is pretty good.. live is very choppy when recording. sometimes the recordings are choppy as well.. its hit or miss.. never had this problem with any other camera before.. is this camera too much for that router to handle?it could be the router, it could be bad cable or crimps...did you make your own cable? did you use the 568B wiring standard?
Post your settings
Ive tried so many different combinationsPost your settings
I turned the receive buffer down from 6 to 3 mbPost your settings
Ok ill try thanks ill report backif its choppy in the web interface, changing blue iris setting wont help...try reducing the fps and iframe interval to 15.
The switch will allow data to go from the camera to pc without passing through the router...since your are not using POE you can get a cheap 20 dollar gigiabit switch like thisI have 2 dome ptz cameras can you point me to what i need? Im soon to be getting a new good router.. would that help or do i need this switch? What does the switch do? Thanks
I dont know man, i think you may have solved the issue.. i know i tried fps to 15 before but not the iframe interval to 15 that i can remember.. seem like its pretty damn smooth right now and i have it up to the highest resolution on 264.. thanks buddy.. ill keep playing with it but the frame rate at 15 each seems to be the ticket..The switch will allow data to go from the camera to pc without passing through the router...since your are not using POE you can get a cheap 20 dollar gigiabit switch like this
https://www.amazon.com/NETGEAR-Ethe...qid=1517005738&sr=1-5&keywords=gigabit+switch
you can buy a managed poe+ switch that supports your cameras for about 60
you generally want to match them...I d
How much will that switch improve performance on say 3 ip cameras?The switch will allow data to go from the camera to pc without passing through the router...since your are not using POE you can get a cheap 20 dollar gigiabit switch like this
