tibimakai Known around here May 8, 2017 1,053 529 Los Angeles Mar 17, 2022 #21 I was referring to the camera lens itself(ball).
T Timokreon Getting comfortable Feb 25, 2022 936 1,722 Chicago Mar 17, 2022 #22 No, I have not taken apart the black ball, the actual camera enclosure. 4 screws, looks easy enough, but I'm not sure what is inside that camera assembly. I have taken the encasing apart, where I found the 3 LED's and taped them up.
wittaj IPCT Contributor Apr 28, 2019 32,919 62,994 USA Mar 17, 2022 #23 At this point you either run it in color or pop it open. It has to be something inside at this point - smear on internal lens or some led in the ball
T Timokreon Getting comfortable Feb 25, 2022 936 1,722 Chicago Mar 17, 2022 #24 I might try opening it up this weekend. Thanks for the replies.
tibimakai Known around here May 8, 2017 1,053 529 Los Angeles Mar 17, 2022 #25 I didn't say to take the ball apart, just look at the tiny camera's lens surface, and try cleaning it. Or at least, if you see something on it. https://www.renhotecic.com/image/cache/catalog/Smart-Module/1080P-F20-HD-Focusing-SONY307-Network-Surveillance-Camera-Module-XM530-Black-Light-Full-Color-2-Mill-1528813-5017-1000x1000.jpeg
T Timokreon Getting comfortable Feb 25, 2022 936 1,722 Chicago Mar 17, 2022 #26 I've done that. Looked at the surface of the lens, cleaned it off, etc..middle part is the flare then haze over the right side still present after.
