Dahua NVR5216P-EI2 / EmpireTech #NVR16CH-16P-2AI-S2
Sep 5, 2016
35,395
83,331
The Swamp
Yep, went over it on the phone with Jeff as well and can't figure out why mine wont create a databse?
What browser are you using?
Hi Bigredfish
Don't want to tell you how to suck eggs! How are the issues with control via direct connection via NVR/monitor, obviously not via web browser. Or utilise a different browser. I've almost given up with edge as latest updates has caused multiple issues even controlling my elderly NVR 5/4KS2. I've found the brave browser more useful.
Hi @bigredfish ,
Looking at your videos for creating a database, it seems the NVR does not has any disk space to store a database :
Maybe you have to look into the hardware connection of the disks or any other disk config in the NVR setup?
Hi Bigredfish
Have tried Brave, Edge, IE, Chrome, Pale Moon
Hi @bigredfish ,
Why is it recording video then?
Pretty sure once they record full it always shows that
And SMART shows all OK
