bzcomputers
Thank you very much for this post. Do you think the 5416-16P-4KS2E also uses the same fan?
I would be surprised if they weren't the same, since the specs between the 5216 and 5416 are so close.
Is it possible to get a variable speed fan? One that blows more when it's hotter, and less when it's colder?
For example, my temperature controller for my smoker is a variable speed fan. Depending on how close the temperature is to my desired temperature, it will blow at different speeds. If it's well below the desired temperature, it will blow at full speed.
Updated: This NVR does have a "smart fan" setup. As internal (CPU) temperature rises the case fan RPM increases. When I was testing with just one camera hooked up the CPU temperature sat around 50C and the case reported 3800RPMs on the fan. You can also manually force the case fan to "Full-Speed" from the default "Self-adaptation" in the settings, doing this with the same one camera attached reported 7500RPMs (noticeably louder, with a whine). Even after running for about 10 minutes at the forced "Full-speed" setting the CPU temperature didn't drop any lower than 47C. Room temperature during this test was about 72F/22C. Upon initial bootup of NVR from cold the CPU reported 35C and quickly (within a minute) rose to 45C, then with the factory fans in use the CPU seemed to hover around 50C-52C with the one POE camera connected.
Are you going to make the switch?
I will test again in a couple days when I get it setup with 9 - IPC-HDW5231R-ZE. I will see what kind of temps are seen then for the CPU and if they don't climb much higher I may try swapping the fans for some quiet ones. I should also point out with just one camera connected the CPU was only reporting 1% usage and it was still within 5C of the recommended max operating temperature of the NVR of 55C. So there isn't much temperature room to play with.
