Приветствую! Прошу помощи в восстановлении сетевого видеорегистратора Dahua. При включении аппарата происходит циклический перезапуск (Bootloop).
Аппаратная часть и платформа:
1. Полный лог старта из UART (консоль RS-232)
Bootrom start
Boot Media: SPI_NAND
Decrypt auxiliary code ...OK
Entry boot auxiliary code
Auxiliary code - v1.00
DDR code - V1.1.2 20160205
Build: Apr 19 2016 - 20:18:19
Reg Version: v1.5.1\
Reg Time: 2017/04/10 14:34:20
Reg Name: hi3798cv2dmd_hi3798cv200_DDR3-1866_1GB_16bitx2_4layers.reg
Boot auxiliary code success
Bootrom success
System startup
Relocate Boot
Jump to C code
Compressed-boot v1.0.0
Uncompress......................Ok
System startup
Relocate Boot
Jump to C code
Fastboot 3.3.0-svn4784 (jenkins@3a6b5acb4427) (Jul 30 2020 - 03:57:06)
Nand: WINBOND W25N01GV
SDK Version: HiSTBLinuxV100R005C00SPC031_20160601
logo........... Logo_Main!
cramfs: wrong magic
cramfs_read_super_buffer error!
cramfs_load_buffer error!
getenv bootnandflash fail
###LOAD ERROR<0> for /usr/data/hardware.lua!
I2C_DRV_Write|153 wait timeout!
Hit any key to stop autoboot: 0
USB0: Register 1111 NbrPorts 1
USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
0 Storage Device(s) found
usb device not found
switch init success!
NET_autoLipDetect timeout
T T T T T T T T T T
Retry count exceeded; starting again
not support this cmd
Wrong Image Format for bootm command
ERROR: can't get kernel image!
2. Список доступных команд в Fastboot (Help)
? - alias for 'help'
autoup - load update file from server
boot - boot kernel from uboot
bootm - boot application image from memory
clear_bootf- clear Hibernate!! bootflag
devid - devid - set hardware id and save to flash
eracfg - eracfg - erase config sectors
eralogo - eralogo - erase logo sectors
fb_needreset- fb_needreset - frontboard read shift key
fb_set - fb_set - get shift key
get_key - get_key - get shift key
help - print command description/usage
hibernate- Hibernate!! boot
kaimendaji- - kai men da ji
lock_otp- lock_otp - otp lock
lock_status- lock_status - get otp lock status
mac - mac - set mac address and save to flash
mac1 - mac1 - set mac1 address and save to flash
nand - NAND sub-system
nandops - flwrite - write img data into FLASH from memory
otp_burntoecurechipset- Burn to secure chipset, please be careful !!!
otp_getcustomerkey- otp_getcustomerkey
otp_getstbprivdata- otp_getstbprivdata
otp_printf- otp_printf - printf otp value
otp_setstbprivdata- StbPrivData
otpreadall- read otp ,for example otpreadall
otpwrite- write otp ,for example otpwrite adddress value
partload- partload - load binary file from a partition
ping - send ICMP ECHO_REQUEST to network host
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
show_hello- - hello world
usbupdate- usbupdate - update the system via USB_DISK, without console
version - print monitor version
xhprint - - hello world
xhprintenv- print environment variables
3. Лог сетевой активности (Запросы к TFTP на ПК)
Сеть физически исправна, регистратор успешно пингует сервер (host 192.168.1.254 is alive), но автоматика не отрабатывает. Вот логи из Tftpd64 Log Viewer при вызове команд:
# При вводе команды 'autoup':
T T T T T T T T T T
# В логе TFTP-сервера на ПК падают следующие запросы:
Connection received from 192.168.1.108 on port 1502
Read request for file <ID_000000000000000000.txt>. Mode octet
File <ID_000000000000000000.txt> : error 2 (Не удается найти указанный файл)
Connection received from 192.168.1.108 on port 4082
Read request for file <uImage>. Mode octet
Что уже было сделано (Манипуляции):
Поделитесь, пожалуйста, правильным содержимым скрипта/текстового файла для подсовывания через autoup конкретно под эту платформу (ID_000000000000000000.txt / update.txt)
Прошивку DH_NVR4XXX-4KS2_MultiLang_V3.216.0000003.0.R.190521.bin брал тут, и 7zip доставал с bin
- Процессор : HiSilicon Hi3798CV200
- Флеш-память : SPI NAND WINBOND W25N01GV
- ОЗУ : DDR3 1GB
- Лог загрузчика : Fastboot 3.3.0-svn4784 (30 июля 2020 г.)
- Файл последней прошивки, стояла : DH_NVR4XXX-4KS2_MultiLang_V3.216.0000003.0.R.190521 (или аналогичная из этой ветки).
Bootrom start
Bootrom success
System startup
Relocate Boot
Jump to C code
System startup
Relocate Boot
Jump to C code
cramfs: wrong magic
USB EHCI 1.00
T T T T T T T T T T
T T T T T T T T T T
- Команда xhprintenv: При вводе команды консоль ничего не возвращает (пустая строка). Похоже, область переменных среды (Environment) полностью повреждена или затерта. Из-за этого также сыплет ошибку getenv bootnandflash fail.
- Команда eracfg: Отрабатывает успешно (erase config sectors done), но погоды не делает, так как разделы системы лежат в дефолте или побиты.
- Команды flwrite, nandops, nand write: В ручном режиме возвращают Unknown command или not support this cmd. Обычный синтаксис ввода заблокирован защитой Fastboot.
- Команда partload: Не принимает прямые шестнадцатеричные адреса (выдает синтаксис partload [off] [filename]), ручная загрузка файлов в ОЗУ не проходит.
- Команда usbupdate: На этапе старта загрузчик выдает 0 Storage Device(s) found / usb device not found. Флешки в формате FAT32 (с файлом update.bin) не монтируются ни в одном из портов, команда виснет.
- Файл ID_000000000000000000.txt: Создавал на ПК текстовый файл разметки с таким именем под подсеть 192.168.1.254, ложил туда uImage и образы. При вызове autoup регистратор все равно уходит в NET_autoLipDetect timeout.
