what was your old NVR model?
Were you using the NVR’s built in PoE ports? Same on new one?
If the old one was not AI enabled it’s really just on setup
- giving it the same password as your old one (which should also be same as your cameras)
- setting time/region
then on login
- change IP and gateway to same as old one (it will default to 192.168.1.108)
- set record schedule and mode under Storage
That’s about it.
Plug cameras in one at a time and be sure it assigns them IPs and you see the green indicator showing it’s connected and talking to the NVR
