ermac
I am running a hybrid system of 16 cams (11 WizMind IP cams and 5 HDCVI cams) currently all connected to a XVR (DH-XVR5216-4KL-I2)
The XVR gives the HDCVI cams WizSense AI but I cannot recored on SMD for the IPs or get push notifications for any AI alerts through the XVR.
Only solution is to get a NVR and pull IP cams on to NVR and then pull XVR on to the NVR to get the HDCVI cam channels.
As the IP cams are WizMind cams they carry the AI so I don't need an AI NVR, a pro series will do the job. However I am looking at getting either a Pro Series (DHI-NVR5216-16P-4KS2E) or a WizMind series (DHI-NVR5216-8P-I) NVR. The only feature advantage of getting the WizMind NVR is for the Face Recognition database.
What is everyone ones thoughts between the two NVRs? Should I just go for the WizMind series NVR or is it overkill?
