Fellouss
- Aug 27, 2017
- 13
- 2
I just changed my PSU FAN by the Noctua like everyone did here and it is a game changer, for real!
Thanks everyone!!
 Thanks everyone!!
Yes..the outside wall w holes that the fan blows thru.Hi Thanks for your reply.
You mean cutting the circular mesh around the FAN?
No, for me at 63 yrs changing the power supply fan was enough. The case fan just makes a blowing air sound, not like the siren noise of the power supply fan.Did some of you changed also the fan case (size 40x10)?
Sent from my ONEPLUS A5000 using Tapatalk
All these damn NVR's have fairly noisy fans.Yeah, the Dahua NVR4108HS-8P-4KS2 is noisy and noisier than the previous one I had. It was same model. With ceiling fan and blues on the NVR does not bother me. Are all Dahua NVRs noisy?
What a noise level.
Just replaced my "SUNON EF40101B1-1Q08C-S99" noise generator (the main problem of the noise) with an "NF-A4x10 FLX".
Now my DHI-NVR5208-8P-4KS2E sounds silently, all the noise gone with the wind....
In my recorder you can insert the "NF-A4x10 FLX" directly on the main board as if they already seen the problem and added an 4 point connector with an 3 point possibility to connect an "NF-A4x10 FLX"
Also replaced the "NF-A4x20-FLX" but that doesn't fix much noise.
Inserted an simple SSD disk for recording, speed, and prevent heat.
Also attached the photos, take advantage of them.
Thanks everyone.
Ahh, silly me. I should have just searched instead of clicking the old links in this thread.not when I check it.....it says arrival in a normal time when I put it in my cart and go to checkout....
Yes, I cut the fan mesh guards off.
Ah, sorry to see one of the stocking stuffers you ordered for your wife won't arrive in time for Christmas, flintstone61....not when I check it.....it says arrival in a normal time when I put it in my cart and go to checkout....
It's winter so air is dry and subject to static.My NF-A4x20 PWM fans 40x20mm fan came today. Testing it out on an old Dahua NVR I had laying around before I try it out on my current installed one. Dumb question but how do you remove the fan cable from the PSU's side motherboard thing? Everything is so jammed packed that its hard to get my fingers or pliers in without touching everything.
The plug on the fan-end connector usually has a latch so that it orients the plug properly to provide polarity, insuring the plug won't be installed backwards. They're DC fans and will run backwards or not at all if 3 wire / PWM.So far it still ain't happening. I think its my needle-nose pliers. They have these smooth tips that keep slipping whenever I apply force and slidding off the plastic on to the cables and probably damaging the wires. I might just try out that quieter PSU someone posted, I can't see myself doing this on my main NVR.
Just be careful to not accidentally tune-in to "The View".Ok I actually had to turn on the TV and watch some morning news to get rid of the image of Tony sitting naked at the dining room table wearing a strap around one arm and holding needle nose pliers...
