Dahua NVR Alarm Center HTTP
ahuelbia
Jul 30, 2023
7
my
Hi,
I have a Dahua NVR DHI-NVR4116HS-4KS3 and trying to use the "Alarm Center" using HTTP to my server on the internet, but the TEST keeps on failing.
My server http (nginx) doesnt show any logs of incoming traffic from the NVR, so I checked the packets. There are TCP packets coming in/out of NVR but the size is only 74-bytes, which is too small. I even tried port 80, 443, 8080, but still fails with same symptoms.
Is there something else which I need to configure ?
Do I need to use some special software from Dahua to use Alarm Center ?
