Dahua NVR advice
allen bell
Aug 28, 2017
7
1
I go back to Dahua units that had the ActiveX interface where you could operate the DVR from any Windows device. Over the years many of their 'improvements' may have been necessary but did not, in my opinion, make the system any easier to operate. By the time we got to SmartPSS I became convinced that the authors knew very little about DVRS and even less about Windows. It's hard to imagine so many bugs in one place but there they are. I got used to most of them, of course, but it's still a pain. I looked at other brands and have been assured that, for example HikiVision, is just as buggy just in different ways and that the solution involved a massive upgrade in price to genuine institutional/government-level products.
Then I discovered Blue Iris and I was incredibly impressed with all the work and all the options that went into it. I was in fact not able to get through the learning curve before the eval period expired so I can't say that I saw results that I wanted. If I had the ear of their developers I would suggest that they find someone outside of a programmer - maybe someone in marketing - to make a list of what the average non-technical customers need as defaults and set the software up that way. A way so that 98% of users would never have to even see 90% of the screens. But that's just me.
But anyway all that's just background to my basic questions:
Before I buy a Blue Iris license without even knowing if I can use it ... what about the Dahua NVR line? Does it use the same buggy software? Or does it have it's own buggy software? What's better? What's worse? Or should I just dive into Blue Iris?
your thoughts would be appreciated.
They all have their quirks.
The basic operation of the Dahua NVR interface hasn't substantially changed. It has updated the look/feel but it is basically the same. Probably had more features than when you last used one, but it is basically the same.
