Wireless dont have the required throughput to operate a NVR; and I have the knowledge to knock any wireless device off the network and prevent it from reconnecting while my mobile device is within range.. it has no place in video surveillance.
hook it up with a fiber optic cable if you want to isolate it electronically from the network, need something like these: Amazon.com: TP-Link Gigabit Ethernet Media Converter, Up to 1000Mbps RJ45 to 1000M Single-Mode SC Fiber (MC210CS): Electronics
You should also have adequate insurance on your property that should cover electronics lost by lightning
Old post but do ya have a recommendation for gunshot protection?
For the firmware we normally send with the latest new one, and sometimes i put the latest new firmware on the forum.@EMPIRETECANDY , when I purchasing NVR, do you put there / is there latest available firmware? Or I need to upgrade on my own?
If it is not with latest firmware, what is the version on board? Is it required to do upgrade?
Andl last question: is this NVR working correctly with Chinesee cameras - C-A? And additionally is this nvr able also record from the low-end wifi cams which have onvif?
Hi, I am new to these forums. Please pardon my questions, but I have been reading as much as I can to figure this out. I have been looking at various brands and would up looking at Amcrest then found out about Dahua as the OEM. I like the Dahua NVR 4216 and 5216, but am confused. I see International versions of the NVR at c sidersbly less than the US model numbers. Are the international versions of the N42B3P the same and the US? Will I be able to,update the firmware easily or need to use backdoor or none official downloads?
Thanks, just building my cam list and going with @EMPIRETECANDY, he is very responsive. Is anyone uses the non-POE NVR5216-4KS2 version with non Dahua cameras? I know Amcrest is Dahua OEMed, but may mix some Dahua, Amcrest and Reoloink (some places I care elss about, but want cheap coverage).
I used this NVR with Hikvision cameras. The video recorded fine but the motion detection and IVS functions didn't work. Not worth mixing brands IMO. A rebranded Dahua camera might work just fine. It' still a risk.Thanks, just building my cam list and going with @EMPIRETECANDY, he is very responsive. Is anyone uses the non-POE NVR5216-4KS2 version with non Dahua cameras? I know Amcrest is Dahua OEMed, but may mix some Dahua, Amcrest and Reoloink (some places I care elss about, but want cheap coverage).
Can you post a picture of it?
Well Andy responded to my email that it is a new NVR and he suspects it happened in shipping, which is bunk since is touched up, but at least it works fine. I will now remain very suspicious of these goods going forward. The unit was in a sealed plastic bag so not sure how or when it happened. The unit did have firmware from September, which I upgraded to the latest Dahua version without issue. Now if my darn drive would show up I can get some testing done with my 1 Amcrest camera while I wait for my other cameras from Andy.
