Dahua IPC unbricking / recovery over serial UART and TFTP
I have read the thread and others quite a few times and haven't seen anything to answer my problem. I admit i am not the best when it comes to doing this kind of stuff that's why i have come to this board hoping someone with knowledge could help me. I would not have got this far without the information from this thread. So if anyone can help please do. Thanks
Sorry, but when I look at your posts, I guess you did not even understand how it is supposed to work.
Your bootloader does not even try to download anything.
I see. We dont even know what device it is. There is by far too many questions open: cam type, fw you are tryin to flash, pc setup, network setup, ... Your setup is for sure not as it should be.
As I said, pls. read the tread again - I am convinced you did not understand it, sorry.
Have a problem when unbricking my VTO2000.
Try to write this firmware 501655_General_Overseas_VTOXXX_Eng_P_16M_SIP_V1.000.00.0.R.20170425.
TFTP is calling. ...
Putty issue. ...
At the end comes the error message: HWID error, please set hwid first !!!!!!!!!
Code:
Checking DDR......OK
UBL Version: 1.46t(DM365)09:30:17 Sep  2 2014
 Oscillator: 24MHZ
 ARM Rate: 216 MHZ
 DDR Rate: 173 MHZ
 BootMode: SPI
Starting SPI Memory Copy...
DONE
U-Boot 1.3.6 (jerry) (Sep  2 2014 - 09:44:01)
DRAM:  128 MB
SF: Got idcode c2 20 18 c2 20
In:    serial
Out:   serial
Err:   serial
Ethernet PHY: GENERIC @ 0x05,id:221513
total gio 2
gio[22]=1
gio[25]=1
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Filename 'upgrade_info_7db780a713a4.txt'.
Load address: 0x80100000
Loading: #
done
Bytes transferred = 163 (a3 hex)
Filename 'custom-x.cramfs.img'.
Load address: 0x81a00000
Loading: ##
done
Bytes transferred = 16448 (4040 hex)
## Checking Image at 0x81a00000 ...
   Header CRC Checking ... OK
   Image Name:   custom
   Image Type:   ARM Linux Standalone Program (gzip compressed)
   Data Size:    16384 Bytes = 16 kB
   Load Address: 02060000
   Entry Point:  02080000
   Data CRC Checking ... OK
Programing start at: 0x00060000
write : 100%
done
Filename 'kernel-x.cramfs.img'.
Loading: #################################################################
done
Bytes transferred = 1682736 (19ad30 hex)
   Image Name:   linux
   Image Type:   ARM Linux Kernel Image (gzip compressed)
   Data Size:    1682672 Bytes =  1.6 MB
   Load Address: 02080000
   Entry Point:  02280000
Programing start at: 0x00080000
write : 100%
done
Filename 'romfs-x.cramfs.img'.
done
Bytes transferred = 3117120 (2f9040 hex)
   Image Name:   romfs
   Data Size:    3117056 Bytes =  3 MB
   Load Address: 02280000
   Entry Point:  02580000
Programing start at: 0x00280000
write : 100%
done
Filename 'user-x.cramfs.img'.
done
Bytes transferred = 5910592 (5a3040 hex)
   Image Name:   user
   Data Size:    5910528 Bytes =  5.6 MB
   Load Address: 028e0000
   Entry Point:  02ee0000
Programing start at: 0x008e0000
write : 100%
done
Filename 'web-x.cramfs.img'.
done
Bytes transferred = 1491008 (16c040 hex)
   Image Name:   web
   Data Size:    1490944 Bytes =  1.4 MB
   Load Address: 02580000
   Entry Point:  02780000
Programing start at: 0x00580000
write : 100%
done
Filename 'data-x.cramfs.img'.
done
Bytes transferred = 815168 (c7040 hex)
   Image Name:   data
   Data Size:    815104 Bytes = 796 kB
   Load Address: 02ee0000
   Entry Point:  03000000
Programing start at: 0x00ee0000
write : 100%
done
Filename '.FLASHING_DONE_STOP_TFTP_NOW'.
Load address: 0x82000000
Loading: #
done
string value is The end of file
Filename 'success.txt'.
Load address: 0x80200000
Loading: #
done
Erasing SPI flash...Writing to SPI flash...done
HWID : <NULL>
HWID : ^
HWID error, please set hwid first!!!!!!!!!
DHBOOT#
Hi everyone. Looking for advice my intercom VTO1220 constantly reboots.
I tried to reboot the firmware does not help what else can be done?
The web interface does not work. Under connecting writes and reboots.
Oscillator: 24MHZ
ARM Rate: 432 MHZ
DDR Rate: 340 MHZ
BootMode: SPI
DONE
DRAM: 128 MB
SF: Got idcode 01 20 18 03 01
In: serial
Out: serial
Err: serial
total gio 2
gio[22]=1
gio[25]=1
Loading: *
Retry count exceeded; starting again
Fail to get info file!
Init error!
Filename 'failed.txt'.
Loading: *
==>use default images
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Linux-2.6.18_pro500-davinci_evm-
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1771112 Bytes = 1.7 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux...................................................................................................................... done, booting the kernel.
Code:
 Oscillator: 24MHZ
 ARM Rate: 432 MHZ
 DDR Rate: 340 MHZ
 BootMode: SPI
DONE
DRAM:  128 MB
In:    serial
Out:   serial
Err:   serial
total gio 2
gio[22]=1
gio[25]=1
Loading: *
Init error!
Loading: *
.DHBOOT# run up
TFTP from server 192.168.1.1; our IP address is 192.168.1.108
Filename 'update.img'.
done
Bytes transferred = 12933288 (c558a8 hex)
## Checking Image at 0x81a00040 ...
   Image Name:   linux
   Data Size:    1771176 Bytes =  1.7 MB
write : 100%
done
## Checking Image at 0x81bb0728 ...
   Image Name:   romfs
   Data Size:    3100672 Bytes =  3 MB
write : 100%
done
## Checking Image at 0x81ea5768 ...
   Image Name:   user
   Data Size:    6221824 Bytes =  5.9 MB
write : 100%
done
## Checking Image at 0x824947a8 ...
   Image Name:   web
   Data Size:    1409024 Bytes =  1.3 MB
write : 100%
done
## Checking Image at 0x825ec7e8 ...
   Image Name:   data
   Data Size:    372736 Bytes = 364 kB
write : 100%
done
## Checking Image at 0x82647828 ...
   Image Name:   product
   Data Size:    45056 Bytes = 44 kB
   Load Address: 028c0000
   Entry Point:  028e0000
Programing start at: 0x008c0000
write : 100%
done
## Checking Image at 0x82652868 ...
   Image Name:   custom
   Data Size:    12288 Bytes = 12 kB
write : 100%
done
The issue has been resolved! Thank you for your forum. Helped to install the high version and then return the old one. It's working.
That's a great post, well done and thanks for sharing!
If / when I get a Dahua camera (not convinced I'll get good functionality with Hikvision NVRs) I suspect it will come in very useful.
Dahua have included / retained a lot of useful functionality in their U-boot, unlike Hikvision who strip it to an almost useless state in pursuit of their 'let's make using our products difficult for our knowledgeable customers' stupid strategy.
can you tell me your contact information I need your help ?
Hello , this is what i got and i can't type any thing , please help me .
Easy recovery without serial: Dahua IPC EASY unbricking / recovery over TFTP
Hello,
I broke my camera by accident while messing with the firmware and had to recover it.
Since I am not the only one that this has happened to and will probably not stay the last one: Here is a simple tutorial on how to unbrick your Dahua IP camera.
Warning: The cameras serial port is 3.3 Volts, do not try to use RS232 which is 12 Volts!!
For this you need:
  • A broken camera with the bootloader still working - assume it is working if you don't know.
    • If you know it is not working, look *here* and don't be afraid to ask
  • A serial UART device, such as:
    • Raspberry Pi or any other microcontroller/devboard with UART
    • USB to serial converter: These can be bought for *very* cheap from china:
    • Connection Settings:
      • Baud Rate: 115200
      • Parity: None
      • Bits: 8
      • Stopbits: 1
      • Flow control: None
      • (CR/LF Auto)
  • Working firmware.bin for your device, use the chinese one if you aren't sure!
  • A TFTP server
    • You should be able to figure this out by using Google.
First of all you have to locate the RX (receive) and TX (transmit) pins on your camera:
On my IPC-HFW4431M camera (and probably all other generation 3/Eos cameras) they can be found very easily:
For other cameras this page on the Dahua wiki should prove useful: ResetIPCamera - Dahua Wiki
On most devices the serial port consists of 4 pins/pinheads which are made up of VCC,GND,RX,TX.
You can connect the GND (Ground, -) of your dongle to the metal casing of your camera.
VCC (+) should not be connected.
You can identify the TX (transmit) pin of your camera by connecting it (press wire against pin) with the RX pin of your serial device.
Though be aware that some dongles swap the labels like so:
Dongle says RX, but it is actually TX of the dongle and wants to be connected with RX of the other device.
If you power up your camera and see text scrolling down your terminal you have found the right pin, keep trying if you don't ^^
Now put a brick on your * key with your terminal window in focus.
Try to find the RX (receive) pin of the camera and connect it with the TX pin of your dongle.
Power up the camera, wait a second, if you see the following message you have succeeded:
Code:
U-Boot 2010.06-svn3089 (Jul 22 2016 - 19:15:59)
DRAM:  1 GiB
gBootLogPtr:80b80008.
Check spi flash controller v350... Found
Spi(cs1) ID: 0xC8 0x40 0x18 0xC8 0x40 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"GD25Q128"
partition file version 2
rootfstype squashfs root /dev/mtdblock7
In:    serial
Out:   serial
Err:   serial
TEXT_BASE:81000000
Net:   PHY found at 3
Hit any key to stop autoboot:  0
Type help to see all available commands:
Code:
> help
?       - alias for 'help'
base    - print or set address offset
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
bootf   - boot from flash
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
cfgRestore- erase  config and backup partition.
cmp     - memory compare
cp      - memory copy
crc32   - checksum calculation
crypt   - crypt
erasepart- erasepart
exit    - exit script
false   - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
flwrite - flwrite - write data into FLASH memory
fsinfo  - print information about filesystems
fsload  - load binary file from a filesystem image
go      - start application at address 'addr'
help    - print command description/usage
hwid    - hwid      - set hardware id and save to flash
kload   - kload  - load uImage file from parttion
lip     - lip      - set local ip address but not save to flash
loadb   - load binary file over serial line (kermit mode)
loady   - load binary file over serial line (ymodem mode)
logsend - get log buf
loop    - infinite loop on address range
mac     - mac      - set mac address and save to flash
md      - memory display
memsize - memsize        - set mem size
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mtest   - simple RAM read/write test
mw      - memory write (fill)
nm      - memory modify (constant address)
partition- print partition information
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
rarpboot- boot image via network using RARP/TFTP protocol
rdefault- rdefault    -recover default env
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv  - set environment variables
sf      - SPI flash sub-system
showvar - print local hushshell variables
sip     - sip      - set server ip address but not save to flash
sleep   - delay execution for some time
smi     - MII utility commands
sync_uboot- sync_uboot - sync uboot to uboot-bak
test    - minimal test like /bin/sh
tftpboot- tftpboot- boot image via network using TFTP protocol
true    - do nothing, successfully
uartUp  - uartUp- update image via uart using uart4
usleep  - delay execution for some time
version - print monitor version
The guys from Dahua have done something right for once and added some helpful commands for us, type printenv to print the U-Boot Environment, you should be able to find these lines among other stuff:
Code:
ipaddr=192.168.1.108
gatewayip=192.168.1.1
netmask=255.255.255.0
serverip=192.168.1.4
da=tftp 0x82000000 dhboot.bin.img;flwrite;tftp 0x82000000 dhboot-min.bin.img;flwrite;
dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite;
dk=tftp 0x82000000 kernel.img;flwrite;
du=tftp 0x82000000 user-x.squashfs.img; flwrite
dw=tftp 0x82000000 web-x.squashfs.img; flwrite
dp=tftp 0x82000000 partition-x.cramfs.img;flwrite;
dc=tftp 0x82000000 custom-x.squashfs.img; flwrite
up=tftp 0x82000000 update.img;flwrite;
tk=tftp 0x82000000 uImage;bootm;
dh_keyboard=1
appauto=1
Use setenv to adjust the network settings:
  • ipaddr -> The IP address of the camera
    • setenv ipaddr 192.168.1.108
  • gatewayip -> The IP address of your networks gateway (router)
    • setenv gatewayip 192.168.1.1
  • netmask -> The netmask/subnet of your network
    • setenv netmask 255.255.255.0
  • servip -> The IP address of your computer (that runs the TFTP server)
    • setenv serverip 192.168.1.4
You can test the connection to your PC by runing ping $serverip
Code:
> ping $serverip
ETH0: PHY(phyaddr=-1, rmii) link UP: DUPLEX=FULL : SPEED=100M
MAC:   00-12-34-56-78-91
Using gmac device
host 192.168.1.4 is alive
(Okay actually I don't even know if Windows will reply to pings by default - so I guess you can ignore this for now)
Extract the firmware image for your camera somewhere, use some ZIP program like 7zip. It might complain about invalid ZIP file (since Dahua changes the ZIP header from PK to DH) you can either fix the ZIP with a HEX editor or use another program to unzip it.
Start the TFTP server and point it to the files you have extracted from the firmware image.
And now for the final part: Flashing the firmware!
I'll flash following partitions in order:
  • romfs (root linux filesystem with busybox)
  • kernel (The holy Linux Kernel)
  • user (Dahuas programs and kernel modules)
  • web (Webinterface)
  • partition ("Partition table" - text files which describe the layout on the flash chip)
  • custom (Language files)
Do not flash the bootloader! There is no need to and when you fuck that up recovering is a lot harder.
Run following commands one after eachother:
Code:
run dr
run dk
run du
run dw
run dp
run dc
Example output:
Code:
> run dr
MAC:   3C-EF-8C-FA-E7-88
Using gmac device
TFTP from server 192.168.1.4; our IP address is 192.168.1.108
Download Filename 'romfs-x.squashfs.img'.
Download to address: 0x82000000
Downloading: #################################################
done
Bytes transferred = 909376 (de040 hex)
## Checking Image at 82000000 ...
   Legacy image found
   Image Name:   romfs
   Data Size:    909312 Bytes = 888 KiB
   Load Address: 002f0000
   Entry Point:  003d0000
Programing start at: 0x002f0000
SPI probe: 16384 KiB hi_sfc at 0:0 is now current device
write : 0%
write : 0%
write : 7%
write : 14%
write : 21%
write : 28%
write : 35%
write : 42%
write : 50%
write : 57%
write : 64%
write : 71%
write : 78%
write : 85%
write : 92%
write : 100%
done
You can run save if you want to save the environment variables you have set (ipaddr, servip, ..).
Run boot to boot the camera :)
Congratulations!
(If you just read this for fun and do not have a bricked camera I still suggest you to buy a serial UART dongle, they're cheaper than most snacks and you can save lots of devices with it!)
(If this helped you and you have some spare for a student: paypal.me/BotoX)
I have a broken camera ,and I fogot where I place , so I use a good hdw4433c-a to test , but when connected with serial port , it displays more information , how I interrupt it . as follows:
U-Boot 2010.06-svn4537 (Dec 14 2017 - 05:06:35)
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
TEXT_BASE:81000000
Net: PHY found at 3
ETH0: PHY(phyaddr=-1, rmii) not link!
Try again use backup_serverip
Failed to get info.txt
Init error!
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-3.4.35
Data Size: 1453664 Bytes = 1.4 MiB
Loading Kernel Image ...OK
OK
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
cmdLine mem=85M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
crashflasg:1, logmagic:54410011.
Starting kernel ...
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
TEXT_BASE:81000000
Net: PHY found at 3
Init error!
OK
Starting kernel ...
Привет родимые!
Проблема с DVR Dahua DHI-NVR2104-S2 2016 года выпуска.
Во время загрузки висит на Логотип Dahua затем через 2 минуты уходит в перезагрузку и так постоянно.
Подключение к USB-TTL, и вот что он мне дал:
U-Boot 2010,06-svn2926 (13 октября 2017 - 15:09:30)
Проверка флэш-памяти контроллера V100 ... Найдено
SPI-Нор (CS 0) ID: 0xC2 0x20 0x18
Блок: 64KB Chip: 16Мб Название: "MX25L128XX"
SPI Nor Общий размер: 16Мб
Окружающая среда SPI флэш инициализируется
В: последовательный
Выход: последовательный
Err: последовательный
Тип чипа hi3520dv300
DPLL: 400Mhz DDR: 1600МГц
APLL: 800Mhz VPLL0: 162Mhz
miiphy_link, 524,7849
miiphy_duplex, 416,0
miiphy_speed, 345,0
Eth0: PHY (phyaddr = 0, rgmii) связать: ДУПЛЕКСА = HALF: СКОРОСТЬ = 10M
MAC: 4C-11-BF-6F-9F-8B
PHY ID: 0x1cc816
хорошая находка PHY RTL8201 на higmac
hwid_gpio_val = 0x18
DDR: 256M
Нажмите любую клавишу, чтобы остановить AutoBoot: 0
USB-устройство не найдено
### Cramfs загрузки 'bmp_logo.bmp' в 0x81000000
BMPW: 300 BMPH: 113 бит: 16 biSizeImage: 67802 bmp_size = 67802
miiphy_speed, 345,0
Eth0: PHY (phyaddr = 0, RMII) связать: ДУПЛЕКСА = HALF: СКОРОСТЬ = 10M
TFTP с сервера 192.168.254.254; наш IP-адрес 192.168.1.108; отправка через шлюз 192.168.1.1
Скачать файл «ID_2G02990PAZ00274.txt».
Скачать по адресу: 0x82000000
Загрузка: TTT
Превышено допустимое число попыток; начиная снова
TFTP получать не удалось, пожалуйста, проверьте чистую окружающую среду
### SquashFS загрузки '/ загрузки / uImage' для 0x82000000
## Загрузка ядра из Наследства изображения на 82000000 ...
Название изображения: Linux-3.10.0
Тип изображения: ARM Linux Kernel Image (несжатый)
Размер данных: 2193464 байт = 2,1 MiB
Нагрузка Адрес: 80008000
Точка входа: 80008000
Загрузка образа ядра ... OK
Хорошо
Запуск ядра ...
Распаковка Linux ... сделано, загрузка ядра.
Скажите мне, что вы можете делать с ним?
Никаких проблем нет с этим уже давно, читай форум и инструкции по восстановлению или сбросу конфигов.
Остановить загрузку
Дальше
setenv dh_keyboard 0
saveenv
reset
Увидишь причину падения и работу watchdog
А дальше помодульное восстановление или через update.img, специальный файл.
Прошивки все доступны, как и русскоязычные форумы, а то тут админы и некоторые начнут ворчать, что ты бы еще на клингонском бы написал и т.п., .. ;)
Остановить загрузку
Дальше
saveenv
reset
Thanks friend! Tell me at least what topics to read to restore it?
