Hello
Can someone help me, i have probably a chineese IPC-HDBW4631R-ZS, i tried to update with this FW (DH_IPC-HX5X3X-Rhea_MultiLang_PN_Stream3_V2.800.0000012.0.R.190808.zip)
But it dont let me connect to the web.
Device-Type:    IPC-HDBW4631R-ZS
Firmware:    2.460.0000000.16.R, Build Date: 2017-09-04
WEB-Version:    3.2.1.491565
ONVIF Version:    16.12(V2.4.0.485616)
Ping is possible, i also tried with TFTP but without success. here is the log:
Ncat: Version 7.40 (
Ncat - Netcat for the 21st Century )
Ncat: Listening on 192.168.254.254:5002
gBootLogPtr:00b80008.
spinor flash ID is 0x1940ef
partition file version 2
rootfstype squashfs root /dev/mtdblock5
gParameter[0]:node=bootargs, parameter=console=ttyS0,115200 mem=130M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc.
TEXT_BASE:01000000
Net:   PHY:0x001cc816,addr:0x00
s3l phy RTL8201 init
MMC:   sdmmc init
Using ambarella mac device
Download Filename 'upgrade_info_7db780a713a4.txt'.Downloading: 100%
  ## file size: 202 Bytes,      times: 0s,      speed: 24.4 KiB/s
done
Bytes transferred = 202 (ca hex)
Download Filename 'romfs-x.squashfs.img'.Downloading: 100%      100%
  ## file size: 2.8 MiB,        times: 2s,      speed: 1 MiB/s
done
Bytes transferred = 2902264 (2c48f8 hex)
curVer:V1.4 <= newVer:V1.4,verCompare success!
[0;32mUBOOT_commonSwRsaVerify run successfully!
[0m
## Checking Image at 02000000 ...
   Legacy image found
   Image Name:   romfs
   Created:      2019-08-08  11:54:00 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2899968 Bytes = 2.8 MiB
   Load Address: 01b80000
   Entry Point:  01fd0000
   Verifying Checksum ... OK
Programing start at: 0x01b80000 for romfs
SPI probe: 32768 KiB W25Q256FV at 0:1 is now current device
write : 100%
done
crc from program is :f2749777, crc from flash is :f2749777
Download Filename 'kernel.img'.Downloading: 100%
  ## file size: 1.5 MiB,        times: 1s,      speed: 1018.6 KiB/s
done
Bytes transferred = 1575384 (1809d8 hex)
[0m
   Legacy image found
   Image Name:   kernel
   Created:      2019-08-08  11:52:32 UTC
   Image Type:   ARM Linux Firmware (uncompressed)
   Data Size:    1573088 Bytes = 1.5 MiB
   Load Address: 01040000
   Entry Point:  01200000
Programing start at: 0x01040000 for kernel
write : 100%
done
crc from program is :67fdba11, crc from flash is :67fdba11
Download Filename 'user-x.squashfs.img'.Downloading: 100%
  ## file size: 14.8 MiB,       times: 14s,     speed: 1 MiB/s
done
Bytes transferred = 15554808 (ed58f8 hex)
[0m
   Legacy image found
   Image Name:   user
   Created:      2019-08-08  11:53:28 UTC
   Image Type:   ARM Linux Standalone Program (uncompressed)
   Data Size:    15552512 Bytes = 14.8 MiB
   Load Address: 000f0000
   Entry Point:  01000000
Programing start at: 0x000f0000 for user
write : 100%
done
crc from program is :ed82b853, crc from flash is :ed82b853
Download Filename 'web-x.squashfs.img'.Downloading: 100%
  ## file size: 4.8 MiB,        times: 4s,      speed: 1 MiB/s
done
Bytes transferred = 5064952 (4d48f8 hex)
[0m
   Legacy image found
   Image Name:   web
   Created:      2019-08-08  11:53:07 UTC
   Data Size:    5062656 Bytes = 4.8 MiB
   Load Address: 01200000
   Entry Point:  01880000
Programing start at: 0x01200000 for web
write : 100%
done
crc from program is :35944947, crc from flash is :35944947
Download Filename 'partition-x.cramfs.img'.Downloading: 100%
  ## file size: 10.2 KiB,       times: 0s,      speed: 426.8 KiB/s
done
Bytes transferred = 10488 (28f8 hex)
[0m
   Legacy image found
   Image Name:   partition
   Data Size:    8192 Bytes = 8 KiB
   Load Address: 000e0000
   Entry Point:  000f0000
Programing start at: 0x000e0000 for partition
write : 100%
done
crc from program is :bfb829ac, crc from flash is :bfb829ac
Download Filename 'custom-x.squashfs.img'.Downloading: 100%
  ## file size: 734.2 KiB,      times: 0s,      speed: 987.3 KiB/s
done
Bytes transferred = 751864 (b78f8 hex)
[0m
   Legacy image found
   Image Name:   custom
   Created:      2019-08-08  11:55:46 UTC
   Data Size:    749568 Bytes = 732 KiB
   Load Address: 018a0000
   Entry Point:  01970000
Programing start at: 0x018a0000 for custom
write : 100%
done
crc from program is :9276625c, crc from flash is :9276625c
Download Filename 'pd-x.squashfs.img'.Downloading: 100%
  ## file size: 82.2 KiB,       times: 0s,      speed: 733.4 KiB/s
done
Bytes transferred = 84216 (148f8 hex)
[0m
   Legacy image found
   Image Name:   pd
   Created:      2019-08-08  11:55:43 UTC
   Data Size:    81920 Bytes = 80 KiB
   Load Address: 01880000
   Entry Point:  018a0000
Programing start at: 0x01880000 for pd
write : 100%
done
crc from program is :98e9a557, crc from flash is :98e9a557
Download Filename '.FLASHING_DONE_STOP_TFTP_NOW'.Downloading: ##
  ## file size: 0 Bytes,        times: 0s,      speed: 0 Bytes/s
done
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
cmdLine console=ttyS0,115200 mem=130M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc
Thanks for your help
ZHCIP
