nayr
			Yea, i don't mean to hijack the thread.I think this question should be in it's own thread...
Try if it works with IE or Firefox ESR, modern browsers killed the APIs that the camera plugins need.
just use SmartPSS; or keep reinstalling the different plugins..
I can't even find firmware for that camera...Hi guys!
New Dahua cameras (e.g. hfw8331) have fair bug: instead of true 1920x1080 image in 2mp mode this cam gives me scaled down and distorted 3mp image (both for main and third streams).
Is there any way to change this behavior or add custom resolution by rebuilding the firmware?
Thanks!
I am not going to be able to change that, I can only do simple things with reverse engineering/patching.I need image with 16:9 aspect ratio, so cropping top and bottom of the picture is intended when camera switched 3mp->2mp mode.
Thanks.
There is a config with the supported resolutions per model, I never tried adding custom ones - will try on mine later.Thanks!
Is it possible to add any custom resolution this way?
Yeah, I didn't have much luck with them either... (Heavily violating GPL in all of their products)PS: I've already reported to Dahua this issue with 8331 and 81230 series, but with no response.
Thanks a lot! Will wait.There is a config with the supported resolutions per model, I never tried adding custom ones - will try on mine later.
D1
HD1
BCIF
CIF
QCIF
VGA
QVGA
SVCD
QQVGA
SVGA
XVGA
WXGA
SXGA
WSXGA
UXGA
WUXGA
ND1
720P
1080P
1_3M
2_5M
5M
3M
2432x2048
1216x1024
1408x1024
3296x2472
2560x1920
960H
DV720P
2560x1600
2336x1752
2592x2048
1920x1440
2448x2048
2752x2208
WVGA
3840x2160
4096x2160
3072x2048
2048x2048
 I'll try to patch it tomorrow.Hi! Please help me! I need patch "sonia" in next firmware for IPC-HFW1225M. Firmware: 大华股份
Thanks!!!
