Hi all
I have just run 'binwalk' to see if there are any differences between the old firmware and the new and it appears as though the Dahua have started to encrypt there images. Please find differences between old and new.
New:
binwalk romfs-x.squashfs.img
DECIMAL       HEXADECIMAL     DESCRIPTION
0             0x0             uImage header, header size: 64 bytes, header CRC: 0x72AE579C, created: 2019-12-21 01:45:25, image size: 41054208 bytes, Data Address: 0xA0F00000, Entry Point: 0xA4500000, data CRC: 0x1155415A, OS: Linux, CPU: ARM, image type: OS Kernel Image, compression type: gzip, image name: "NVR4X-S2"
3934067       0x3C0773        Zlib compressed data, best compression
6646576       0x656B30        Zlib compressed data, best compression
6647029       0x656CF5        Zlib compressed data, best compression
6647222       0x656DB6        Zlib compressed data, best compression
6655178       0x658CCA        Zlib compressed data, best compression
6658199       0x659897        Zlib compressed data, best compression
6658986       0x659BAA        Zlib compressed data, best compression
6659138       0x659C42        Zlib compressed data, best compression
6659179       0x659C6B        7-zip archive data, version 0.3
18263854      0x116AF2E       7-zip archive data, version 0.4
21253852      0x1444EDC       7-zip archive data, version 0.4
21966244      0x14F2DA4       mcrypt 2.5 encrypted data, algorithm: "~_xa", keysize: 26871 bytes, mode: "2",
22251354      0x153875A       7-zip archive data, version 0.4
24559037      0x176BDBD       Zlib compressed data, best compression
25819743      0x189FA5F       Zlib compressed data, best compression
34672141      0x2110E0D       7-zip archive data, version 0.3
41013320      0x271D048       Zlib compressed data, best compression
41015297      0x271D801       Zlib compressed data, best compression
41019514      0x271E87A       Zlib compressed data, best compression
41025607      0x2720047       Zlib compressed data, best compression
41027481      0x2720799       Zlib compressed data, best compression
41033019      0x2721D3B       Zlib compressed data, best compression
41038786      0x27233C2       Zlib compressed data, best compression
41044255      0x272491F       Zlib compressed data, best compression
41046098      0x2725052       Zlib compressed data, best compression
Old:
0             0x0             uImage header, header size: 64 bytes, header CRC: 0x8C2162AF, created: 2019-08-09 03:56:17, image size: 41463808 bytes, Data Address: 0xA0F00000, Entry Point: 0xA4500000, data CRC: 0x8A9829AD, OS: Linux, CPU: ARM, image type: OS Kernel Image, compression type: gzip, image name: "NVR4X-S2"
64            0x40            Squashfs filesystem, little endian, version 4.0, compression:xz, size: 41459876 bytes, 2660 inodes, blocksize: 131072 bytes, created: 2019-08-09 03:56:17
Maybe this can shed some light why the files aren't being extracted.
