andrewy
How old is this NVR? If its from 2017 or later it may have a default password.
Dahua stopped using default passwords on firmware after 2017 due to it being a security vulnerability, so its worth a try.
Username: admin Password: admin
Username: 888888 Password: 888888
There is also the Dahua Password Generator, again only works on older models:
securitycamcenter.com
Unfortunately if absolutely nothing from this forum works for you then the unit is done for which sucks,
but also the latest available firmware for this NVR is 2021 which is is 3 years old now.
DH_NVR4XXX-4KS2_MultiLang_V4.001.0000005.1.R.210713
Worst case scenario you can get an upgraded/newer replacement for $172, and it will have longer firmware support:
Download Dahua Password Generator (2026 Version) — SecurityCamCenter.com
This tool with generate a daily password that reset the Dahua master password. You just need to run the password generator and enter the actual DVR date to get a new password (the date you see on the screen).
