C crazyazz n3wb Feb 27, 2025 4 1 Australia Feb 27, 2025 #1 Hi, I updated the firmware on my Dahua DHI-NVR2104HS-P-12 and now it has a black screen. It shows the boot up logo etc, and then just goes to a black screen. What can I do to fix it? Thanks
wittaj IPCT Contributor Apr 28, 2019 30,849 59,201 USA Feb 27, 2025 #2 Sounds like maybe the resolution the HDMI is putting out is higher than the monitor. Log into the NVR via a web browser and change the resolution to a lower resolution until it shows up on the monitor.
C crazyazz n3wb Feb 27, 2025 4 1 Australia Feb 27, 2025 #3 OK thanks I will try that. Another problem I had is the camera all went status red with it saying pending. I deleted them all, and then they couldn't be found. Any suggestions on what may be going on?
bigredfish Known around here Sep 5, 2016 25,967 68,811 The Swamp Feb 27, 2025 #4 Reboot. Did you change the password on the NVR? Or cameras?
C crazyazz n3wb Feb 27, 2025 4 1 Australia Feb 27, 2025 #5 No I didnt change it. I tried rebooting etc.
bigredfish Known around here Sep 5, 2016 25,967 68,811 The Swamp Feb 27, 2025 #6 Were you using the web interface or connected to the NVR with a monitor and mouse? What exact FW did you use (Dont upgrade FW )
C crazyazz n3wb Feb 27, 2025 4 1 Australia Feb 28, 2025 #7 Got it all sorted out. Did a uboot reflash. And the router was setup with the same IP range as the POE switch. So all working now. Reactions: bigredfish
