I don't have relay-out but everything else is selected.View attachment 19231
Please check if tick this?
The fact is that is not related to purchasing from andy..its either user error or an issue with all dahua cameras of the same model..Smart codec is off . The fact is I have 7 cameras here that do not work the way they are supposed to.
Thank You .I can tell you that IVS does work on mine and it does record to the on board SD card. Only problem I have with mine is that like everyone else it skip a frame when IVS is triggered in the playback. I am at work now but maybe later today I will try to make a post on a step by step to enable IVS with SD card on this forum.
Thank You .
I will really appreciate it.
Thank You .
All that was done.Insert SD card in the camera (Make sure it at least Class 10)
Storage -> Destination -> “Path” tab (under Record) - on “Event Type” all boxes under “Local” is checked and save
Storage -> Destination -> “Local” tab - highlight SD card then format (Camera will restart after format complete)
Storage -> Schedule -> “Record Schedule” tab – add check to “motion” boxes on all the day and time you want (yellow highlight) and save
Event -> Smart Plan – click on “light bulb” icon (IVS) and save
Event -> IVS – add rule (green plus) select and draw rules, under Parameter Setup – make sure your time and date is setup in “Working Period” and “Record” box is checked. Then save
I would suggest on your laptop to load the camera GUI and go to live view, enable Rules Info (button on bottom of the viewer) and walk around. If IVS is detected it will flash the IVS lines you drew then it should be recording to the SD card. I would go check in the Playback Tab in the camera GUI and look on the timeline at the bottom to see if any "yellow" lines/boxes showed up.
All that was done.
Rules work and send email to me.
But when I go to back up to review playback the only thing available is green general recording. When I select anything else like alarm and intelegent it says no recordings on the web Gui and also smartPSS
Ivs does not even show when smart codec is enabled.
Then I have no idea what to tell you to check next. Did you reset to default after the firmware upgrade if you upgraded it?
Maybe reset it back to default in the configuration so you still keep the username/password and network setting but go directly to SD and IVS set up. Do a simple tripline rule type to try it. Either the camera is defective or the processor in camera is overloaded. I run mine at default bitrate and 15 fps on both.
So, when you're in SmartPSS playback section, you see this right?
Now, click the Event tab in the lower left hand side and you should see this...
Now in the Record Type column, the blank cells are the IVS events. You're not seeing any of those? You're searching for "all" in the Type box of the lower right hand corner right?
I use the black 2.0 version
I am thinking there might be a bug somewhere to record IVS to the SD card. I been messing around with IVS and SD card to see if I could make it stop recording and it did stopped but I had no idea what step did I do to make this bug show it ugly rear end. I had to go back and re-save everything to make it start recording IVS to the SD card again.
I never bothered to check SmartPSS until tonight and I noticed that on SmartPSS the yellow is intended for motion detection while the orange was for IVS events. But in the camera there is no orange at all, only yellow for both Motion Detection and IVS event. Maybe that what is causing the problem because when I tried to view with SmartPSS, the recording on IVS stopped in the camera and I had to go back to re-save all the IVS setup. The IVS setting did not vanish or change but saving it again cause it to record again.
Try this then, resave all your setting in the camera and go trigger some IVS events but play back only using the camera built in GUI. Do not load your SmartPSS yet.
