TL1096r
- Jan 28, 2017
- 1,211
- 472
im using a Ubiquiti Edgerouter, yes you want to do it on your router.
Ok, using arris router - what area on this router would I need to go to block this.
RTFM?
You wont be able to with your unmanaged switches...Now I want to configure VLAN as well once the switches arrive.
Same here, would be best to be able to troubleshoot a problem for ourselves.
Same with VPN, they do a great job explaining but you have to use google/youtube to find a lot of information.
When I installed my Reolink it was sending information to China it seemed, I turned off some settings and I have not seen the IP popup any longer.
I wonder if Dahua has a backdoor how many others have it but not yet discovered? I feel reolink would have this issue.
I know nayr is all protected from one of his post but wondering if he can look into his models and if he can find out any issues.
then slap your own router/firewall up inbetween it and your LAN and configure it to be a DMZ host
@nayr and @hmjgriffon....
Just so everyone is clear regarding VPN....if you have a VPN set up on your router and no ports forwarded and nothing in the individual camera settings (like UPnP, P2P, whatever that company wants to use) are you pretty much safe from the camera being able to communicate to the outside world or do you still need to VLAN it off or set up FW rules to block ALL outbound traffic? For example, I know in most cameras under network config there are places for IP address, Default gateway, and DNS addresses....I know it's a must to have the IP address set up and the default gateway but can you leave the DNS stuff blank or maybe it won't let you not sure...just thinking of ways the cam could get outside your network.
if its connected to an NVR, its already on its own vlan and I don't think cameras themselves can talk to anything else, you don't have to have a seperate vlan, if your firewall will let you block individual IPs, if not then you need a vlan and to block it. there's lots of ways to do it.
Sorry, but that's not a good assumption - the 'Virtual Host' feature on Hikvision NVRs implicitly enables the Linux kernel 'IP_forward' (not to be confused with port forward) facility such that packets can flow across the NVR LAN and PoE interfaces.if its connected to an NVR, its already on its own vlan and I don't think cameras themselves can talk to anything else,
That's why I said I think lol ive never used one of those nvrsSorry, but that's not a good assumption - the 'Virtual Host' feature on Hikvision NVRs implicitly enables the Linux kernel 'IP_forward' (not to be confused with port forward) facility such that packets can flow across the NVR LAN and PoE interfaces.
So the cameras on NVR PoE ports can easily talk to the outside world.
I'm following all these discussions regarding network security and slowly beginning to understand some strategies. All this networking stuff has my head spinning
I have an Asus router and it has a Network Services Filter option that appears to be a method of denying your ip cams from accessing the Internet. Here's a good discussion on another website - I hope it's OK to link another website. Any input is appreciatedThanks.
I have an Asus router as well so I will take a look at that other discussion link that you posted. Also another question for anyone that might know....is there a specific clear cut way that you can figure out if it's even possible for your current cam to communicate outside your network? Is there some sort of test or other way that you can log onto your camera and see if you can access the net or something?
Well just for giggles I figured I would go home and log onto my router and see if I could find any outbound connections so I viewed my "active connections" log under my WAN section and cam across two of my IP addressed cameras connecting to various outside addresses....not sure what this is all about? Any assistance would be appreciated...
