Acupick is probably good for police with thousands of cameras around a city used to quickly locate the escape route of a crook.
Thank you. Is it normal that in NVR UI in playback when checking "intelligent" parts of a recording everything is recorded 10 seconds too late? I have to check those events manually in general modeYou would set it to record all cameras 24/7 Full Time along with Intelligent recording to allow specific events to be searched
If you are using VMD I often see the alert hashmark appears “late”
I believe this is because VMD needs to see the full object and decide/categorize it as human, vehicle etc.
If you use straight IVS such as Tripwire it usually doesn’t depending on how well you have your rule lines drawn.
