Dahua 5442 cant see it
Doc777
Apr 23, 2022
6
1
RI
Lost power and now can’t see half my cameras. Lorex NVR Wi-Fi doorbell needs to be put on 192.168.0.1. But the NVR keeps assigning everything on the 10.1.1 network. Using the Dahua config app I can’t see anything. Going to do a hard reset on the 5442 and add a netgear GS105P switch again. Last time it crashed my system assigning double IP addresses.
8 Lorax cameras directly into NVR, 2 Dahua plugged into switch then into router. Hope this works as I spent 20 hours already. ChatGPT said it will cause a loop and crash the system but not really believing AI much.
Sounds like maybe the cams reset to default IP and are now in conflict city, or as you said your system assigned same IPs.
