Cycle On /h264 link not working
ditalian
Joined
Nov 29, 2022
Messages
8
Reaction score
1
Hello everybody,
When I try and view the stream through VLC or any other method through this url, the CYCLE does not work. In UI3 it works no problem. Am I doing something wrong?
I have also tried the following only because I noticed in UI3 when you goto the cycle group it does %40 instead of @. I have gone through the manual and it seems to me I am doing it correctly but it just isnt working. It just shows the whole group with no cycle.
Thank you
TonyR
Joined
Jul 15, 2014
Messages
17,476
Reaction score
40,703
Location
Alabama
Put BI's port number after the server IP, colon and before /h264 such as:
Code:
http://192.168.200.250:81/h264......etc., etc.
ditalian
Joined
Nov 29, 2022
Messages
8
Reaction score
1
Code:
Same thing no difference. It connects but its the main group view and does not cycle
ditalian
Joined
Nov 29, 2022
Messages
8
Reaction score
1
TonyR
Joined
Jul 15, 2014
Messages
17,476
Reaction score
40,703
Location
Alabama
looks like your using temp.h264 not temp.ts. Can you try it with the .ts??
temp.h264 is a h.264 stream
where
temp.ts is a mpeg-2 stream which is compatible with more devices
I tried as below and 1) no auto-cycle, showed all 3 cams in the "dogs" group and 2) after 10 seconds, VLC froze, had to terminate VLC with cntl-alt-del.
Same result when auto-cycle "@" omitted.
Code:
http://192.168.200.250:81/h264/@dogs/temp.ts&user=BI-username&pw=BI-password
Now this works OK in VLC:
Code:
http://192.168.200.250:81/mjpg/@dogs/video.mjpg&user=BI-username&pw=BI-password
ditalian
Joined
Nov 29, 2022
Messages
8
Reaction score
1
Code:
Code:
so you agree its a bug with the temp.ts?
ditalian
Joined
Nov 29, 2022
Messages
8
Reaction score
1
I didn't perform exhaustive testing so no, I cannot say for sure, but....VLC does state it can play MPEG-2 files here.
oh VLC plays it just doesn't cycle on the feed. Not VLC specific. I don't actually use the feed for VLC I am just using that to test it.
no cycle on temp.ts
cycle on video.mjpg
The problem is the player I use these urls with only works with the format temp.ts spits out. It does not work with video.mjpg. But would be good to have a feed that cycles.
ditalian
Joined
Nov 29, 2022
Messages
8
Reaction score
1
To update the thread. Ken replied.
The cycle was forgotten to be added to the TS streams.
Ken said its been added to the TO DO list
Top
