Wow, wish I knew half of this when we built our house 15 years ago. If I may also take liberty in going a little off topic but someone may come up with something of interest worth following up on.
There are some fantastic ideas here that I will investigate if we ever do another build or even have the roof replaced.
Ridge vents on roof do not work well, wish we had gone with the whirllybirds from years ago. Damn the asthetics.
2 runs of network cables to multiple spots.
Over the stove vent that vents to outside and not 6" above where the "vent" is located.
Not putting the clothes dryer in the middle of the house with a 25' exhaust vent, instead of locating on an outside wall.
Flooring in the attic.
Conduit to the outer edges of the property for future camera installs/future electric?
ADA compliant (or wider than standard) front and back doors. You'll appreciate it if a relative winds up in a wheelchair, and it makes getting furniture in and out easier.
Since we don't have natural gas lines, 30amp and 50amp generator hookups to the box. 50amp for a whole home, 30amp for a smaller portable if needed.
Each room on it's own circuit breaker. Not 3 outlets in this room, 1 in the hallway, and 1 light fixture on a circuit. I sure wish I had been more involved in the electrical planning of the house where things just made sense.
One thing that helped me the most, I took pictures during every stage of the build. A lot of pictures, of everything. I can't tell you how many times I've referred back to those pictures for network cable runs and camera placement, since I know what is behind soffits, siding, deck boards, and spaces you can't see now, but I know what was behind them as it was built.
) what are your thoughts/experiences with Single vs Two Stage vs Variable Speed AC systems?
