Is there instructions how to do this. My roll back option is greyed out.Cor double check intel driver version in Control Panel, I had to block the automatic update of the driver in group policy. Simple restart means silent upgrade of intel driver. For me intel driver 4664 with BI 4.6.6.0 is rock stable with HA turned on in BI. I have ~30% cpu and 4.1gb of ram now after 24 hours.
CPU usage creeping up slowlyIs there instructions how to do this. My roll back option is greyed out.
Sent from my SM-G955U using Tapatalk
Got it.
Glad I could helpI mentioned to double check because it also happened to me, so initially I thought and reported here that intel 4664 did not solve the issue. But intel 4664 definitelly solves the cpu/memory issue of BI process.
This is the file I got https://communities.intel.com/external-link.jspa?url=https://downloadmirror.intel.com/26772/eng/win64_154518.4664.exe
This is the way to block driver update, maybe you put device ids to comment(?) or the rule is not enabled(?), remember to put all ids, each as a separate entry, for me this method works: View attachment 25407
Dell Inspiron 7050 tower, i7-7700 w/ 16GB RAM -120gb Solid State OS drive and Purple Data drive.What cpu do you have?
Tried Dell's May 2017 driver - no dice. Still high CPU.Tried the driver you linked to:
the HA uses the driver, bad driver causes memory leakIs the problem hardware acceleration or should I use driver 4664?
Did you do a clean install of Windows using the Microsoft media creation tool? If not many OEM versions of windows don't let you install drivers unless provided by the OEM....HELP PLEASE... cant install the driver recommended in that thread:
6th Generation (Skylake) / 7th Generation (Kaby Lake)
Driver Version 15.45.18.4664 is known to be good: <15.45.18.4664: Intel® Graphics Driver>
When I try it says it is not validated for my computer. My computer is a 6th Gen i5, 530 GPU.
google you will see that other software has this issue too...it is specific to h.264 decoding...its just that most packages dont offer quicksync h.264 decodinginstalling 4664 seems to keep the CPU under 60% and memory under 70%
Odd to have a CPU / Memory bug in an Intel driver for a year and seems like only BI 'trips' the problem?
I suspect the problem is something BI is doing - I hope BI fixes the issue so we can use recent, more enhanced, drivers.
