Mike A.
- May 6, 2017
- 4,210
- 7,097
also this shop is down the street they have this one: Used Dell Optiflex 7010 SFF System, Tomcom Link Corp
Dell sells the same direct for $179 USD or better if you catch a good sale. If nothing else might use that to bargain with them.
Dell Refurbished Desktop Computers, shop daily deals from Dell Refurbished Store - 7010 - Intel Core i5 Quad (3rd Gen)
I've used a couple of i5 versions those for a long time now. They work fine as long as you're realistic about it. A bunch of 1 and 2 MP cams at reasonable rates will be OK. Trying to hang multiple 4K cams off of it will kill it quick. Unless you really need something small, then I'd go with a tower version so you have more space for drives.
