Converting EZVIZ C6TC from Chinese to English
Wow!
That's a great result, well done.
I'm curious what the tinkering consisted of.
Was it a matter of changing the devType held in mtdblock2 ?
So the current working camera has US firmware and mtdblock2 has the following mods;
-- 0x10 = 02 (Chinese)
-- 0x55 = 0D (RR region)
-- 0x80 -> 0x91 = 43 53 2D 43 56 32 34 38 2D 41 30 2D 33 32 57 46 52
CS-CS248-A0-32WFR (Model string)
-- 0x04 & 0x05 = Checksum-16 of 0x09 -> 0xFC
When making the same mods on my second C6Tc it is unable to register on the EZVIZ network.
So I wonder if during the course of changing the devType at one point, trying different regions EU, US, RR etc.. at some point it was able to register with the EZVIZ network.
I'm still trying to figure this out..
If I write the paraBlock from the first CN camera to the second CN camera it connects to the EZVIZ network perfectly..
This isn't a solution as you can't have 2 devices with the same serial registered on the EZVIZ network.
It's as if at some point I changed something which allowed that serial number to register with the US servers..
I even tried modifying the date on the second CN camera's serial code in case my serial had become black listed but no luck.
So I went out and bought a CS-CV248-A0-32WFR (US model) and ripped mtdblock2..
The byte values were:
0x10 = 01 (English)
0x55 = C6 (Brazil) - strange as I bought it in Hong Kong
0X64 = D722 (same as CN)
The main things that were different were:
0x1E > 0x23 - Challenge Code
0x35 > 0x3A - Device Mac Address
0x40 > 0x52 - Serial String
0x80 > 0x90 - Model Number String
You can change the device mac, the date part of the serial string and the model number and the device will continue to register on the EZIVZ network.
However if you change the 6 character challenge code or the subserial D4####### then the firmware won't register on with the ML (Amazon AWS) server.. Which makes me think that the challenge code is generated based upon subserial string.
I still don't know what is different about my first CN device that allowed it to authenticate with it's original subserial and challenge key..
I have tried using Ettercap and Wireshark to packet sniff the network traffic but the packets didn't contain any readable strings except for the recurring subserial D4####### which is what makes me believe that it's important.
I guess I'll keep soldiering on..
hello, i just found this forum, i also have an Ezviz CS-CV248-A0-32WFR camera, but it is bound to another account, i am wondering i i can change the sserial number so i ll be able to bind it to another ezviz account? thanks
I went thru whole thread and im under huge impression what kind of tricks you guys were doing - especially omitting RO property :)
I was wondering, if that could not rescue blocked by previous owner camz. When I took QR code, and changed serial number to something else, it allowed me to register new device (obviously without connecting it - it wanted to connect to wifi
Did anyone scanned what camera is speaking via https with external servers? Or is it not https but some different proto?
I am now trying to do the same with CS-H8-V100-1J5WKFL camera. But they've added a lot of security measures so I had to solder off flash chip at dump it.
The mtd2 block contains sec.bin, here is what I found out about its structure:
Serial number is generated of:
0 - 48 charactes (maximum) -> dev_type_readable
2 digits decimal ->decodeChans
8 characters -> serial_date
1 character -> unk_ser2; / 1 - A, 2 - B, other - C
1 character -> unk_ser3; / 1 - A, 2 - B, other - C
2 characters -> region, see enum in 010 Editor template (CH, WR, RR ...)
9 characters -> subserial
dev_type is actually devType_part1 << 16 | devType_part2
Code:
53 57 4B 48 E2 0D 00 00 F4 00 00 00 00 00 01 00
02 00 00 00 02 00 00 00 01 00 00 00 0C 00 58 58
58 58 58 58 00 00 00 00 00 00 00 00 01 00 01 00
00 00 00 00 00 20 BB BC 9C A6 82 00 00 00 00 00
00 32 30 32 33 31 30 32 35 58 58 58 58 58 58 58
58 58 00 09 07 01 01 00 00 01 00 00 01 00 3E 00
00 01 01 00 27 31 01 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
43 53 2D 48 38 2D 56 31 30 30 2D 31 4A 35 57 4B
46 4C 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00
C-like:
typedef ubyte mac_address[6]<read=Str("%02X%02X%02X%02X%02X%02X",this[0],this[1],this[2],this[3],this[4],this[5])>;
uint16 CalcChecksum(uint64 address, uint32 size)
    local uint32 result;
    local uint32 i;
    result = 0;
    for (i = 0; i < size; i++) {
        result += ReadUByte(address + i);
    return result;
enum <ubyte> Region {
    REGION_CH  = 0x01,
    REGION_CH2 = 0x20,
    REGION_TW  = 0x02,
    REGION_TW2 = 0x32,
    REGION_WR  = 0x03,
    REGION_WR2 = 0x30,
    REGION_HK  = 0x04,
    REGION_HK2 = 0x31,
    REGION_BJ  = 0x21,
    REGION_SH  = 0x22,
    REGION_GZ  = 0x23,
    REGION_CD  = 0x24,
    REGION_JP  = 0x33,
    REGION_AS  = 0x34,
    REGION_EU  = 0x35,
    REGION_NA  = 0x36,
    / all other - REGION_RR
enum <ubyte> VideoOutType {
    VIDEO_NO_OUT = 0,
    VIDEO_CVBS = 1,
    VIDEO_HDMI = 2,
    VIDEO_SDI  = 3
typedef struct _SWKHHeader {
    local uint64 start = FTell();
    char magic[4]<bgcolor=cBlue>;
    uint32 checksum; / sum(header[12:])
    uint32 size<bgcolor=cPurple>;
    uint32 unk0; / ???
    enum <uint32> { LANG_EN = 1, LANG_CN = 2 } languange<bgcolor=cAqua>;
    uint32 device_class; / ???
    uint32 unk1;
    uint16 devType_part1<format=hex,bgcolor=cYellow>;
    char verification_code[6]<bgcolor=cLtGreen>;
    ubyte unk2[8];
    uint16 encodeChans<bgcolor=cLtBlue>;
    uint16 decodeChans<bgcolor=cLtGray>;
    ubyte unk3[4];
    ubyte alarmInNums<bgcolor=cWhite>;
    mac_address mac<format=hex,bgcolor=cLtRed>;
    mac_address mac2<format=hex,bgcolor=cLtRed>;
    char serial_date[8]<bgcolor=cGreen>;
    char subserial[9]<bgcolor=cAqua>;
    ubyte videoStandard<bgcolor=cDkGreen>;
    ubyte unk_ser2; / 1 - A, 2 - B, other - C
    ubyte unk_ser3; / 1 - A, 2 - B, other - C
    Region region<bgcolor=cPurple>; / zone
    ubyte has_audio_input<bgcolor=cLtPurple>;
    ubyte unk4;
    ubyte USBNum<bgcolor=cBlue>;
    ubyte unk5;
    ubyte alarmOutNums<bgcolor=cLtBlue>;
    ubyte unk6;
    ubyte has_speaker<bgcolor=cAqua>;
    VideoOutType videoOutType<bgcolor=cLtYellow>;
    ubyte videoInType<bgcolor=cLtAqua>;
    ubyte unk7_0;
    ubyte unk7_1;
    ubyte IRSupport<bgcolor=cBlue>;
    ubyte has_wifi<bgcolor=cLtGreen>; / 1 - yes, 0 - no
    ubyte OnepushFocus<bgcolor=cPurple>;
    uint16 devType_part2<format=hex,bgcolor=cYellow>; / devType_part1 << 16 | devType_part2
    ubyte unk_8;
    ubyte unk_9;
    ubyte unk10[24];
    char dev_type_readable[64]<bgcolor=cLtGreen>;
    ubyte unk11[12];
    ubyte unk12;
    ubyte unk99[51];
    local uint16 real_checksum = CalcChecksum(start + 12, size);
    local uint32 checksum_color = cGreen;
    if (checksum != real_checksum) {
        checksum_color = cRed;
        Printf("Computed checksum = %08X", this.real_checksum);
    local uint64 curr_pos = FTell(); / hack to apply color after
    FSeek(start + 4);
    SetBackColor(checksum_color);
    ubyte bla[4]<hidden=true>;
    SetBackColor(cNone);
    FSeek(curr_pos);
} SWKHHeader;
SWKHHeader header;
Ok, so I patched memory dump as following:
0x10 -> 01
0x45 -> changed date
0x55 -> 03 (world)
Changed dev visual type from CS-H8-V100-1J5WKFL to CS-H8-R100-1J5WKFL
Fixed checksum
After that I flashed memory with these new values and soldered it back to camera.
Flashed newest firmware from by putting it to sd card with name ezviz.dav
Resetted camera, connected it to router via ethernet cable.
With SADP tool activated, with ezviz studio added to my account and now everything is working!
So even new cameras with secure uboot and other stuff can be patched to work in europe.
0x10 -> 01
0x55 -> 03 (world)
Fixed checksum
Hi , i have the same problem with EZVIZ-H6c , can you give me guide line , if possible a software to use , big thanks
Hi,
TLDR; I have installed US firmware on CN hardware but unable to connect to EZVIZ service.
I purchased a couple of C6TC (CS-C6TC-32WFR) IP cams from TaoBao in an attempt to save a few dollars. What I didn't realise was that the cameras are region locked and it requires a Chinese phone number to register the account and the Chinese Android app has to be installed by a sketchy Chinese app-store.
It goes without saying that I don't want to use these cameras on the Chinese network.
The best solution would be to use these devices locally, which I can do using RTSP.. However they are extremely crippled, all PTZ commands and other related functions are transmitted over a proprietary protocol. So what I want to do is try and install the EN firmware on the CN camera so that I can get full use of the cameras.
After some googling I managed to find this datasheet for the US version:
AFAIK it's the US version of the C6TC and you can see in the header of the specifications on page 5 that the model number is CS-CV248-A0-32WFR.
I also found the location of some US firmware for a different model:
So I just substituted the model numbers and came up with this working URL:
CS-CV248-A0-32WFR/2.0/CS-CV248-A0-32WFR.dav
After downloading the US firmware I tried to use the Windows EZVIZ Studio to upload the firmware to the device but was met with 'upload failed!'. I tried tinkering with the DAV file but to no avail, so decided to try something a little different!
I dismantled the camera and found that there is a Micro 4-pin JST connector with nothing attached! It was just my luck that it's a serial connector and the middle pins are TX and RX. I connected them up to my FTDI and gotroot!
I poked around for a bit but couldn't really achieve anything useful, I reset the device and escaped the boot sequence. U-boot had a command (update) which installs 'digicap.dav' from the microSD card.
I dropped the US firmware on an SD card and renamed it 'digicap.dav'. I inserted the card into the device, reset and then typed 'update'. The update failed with the error 'incorrect language'.
I searched the ipcamtalk forums and found hiktools, this allowed me to change the language of the dav file to Chinese. I dropped the updated file on the SD card and ran the update again.. IT WORKED!
The update installed, I reset the camera and English audio queues played! Great!
I opened up EZVIZ studio and tried to configure the device but was confronted with the message "It's not supported" which is different from the previous "The device has not been connected to the EZVIZ"..
This is where I'm currently at; a Chinese device (CS-C6TC-32WFR) running US firmware (CS-CV248-A0-32WFR).. but still unable to connect the device to the US EZVIZ network..
Any ideas?
Where can I download this hiktools?
0x10 -> 01
0x55 -> 03 (world)
Fixed checksum
Can you provide more in sight and steps how to replicate this , the software section and edits ?
