Promod117
- Mar 10, 2014
- 213
- 29
Don't know, maybe 960H vs D1?? The R22 is D1 only. You have a R18 working with BI?
Correct. It will be a few hours before I can check. The evil twins want to go to a school play.....
Bob,
Here are the parameters I am using for my Aposonic R18;
HTTP://***.***.***.***:8000
Make - Generic
Model - JPEG/GIF/etc. image requests
Path - /cgi-bin/wappaint?camera_no=1&animation=0&name=******&password=****&pic_size=3
Media/Video/RTSP Port - 68
Discovery Port - 8999
Camera - 0 or 1 or 2 or 3 etc depending on which camera Remember 0=camera 1
Hope this works for you!
The path is slightly different for each camera. camera_no=
Mine are 1, 2 and 3. The Blue Iris tab must be for reference.
Just so you know they exist, I use a Hikvision analog to IP adapter with different NVR software and it works like a champ. This is a box that you can connect 4 analog cameras to, then it coverts that to IP so when adding to your NVR it is just like adding an IP camera. In my case I add one IP yet I get four cameras showing up with the same IP once added.
Hikvision part DS-6704HWI is what I use. Looks like you will not need this as you will be getting a free way to add them, but at least you know these exist now. I have a single analog camera at many places I need to connect as it is not replaceable with IP at this time so I needed a solution to get it connected when the locations were switched to IP cams, this has worked great so far.
