Fastb
Here's a thread that discussses pros and cons of BI vs NVR.Nice to know BI isn't much harder to setup than NVR's.
Stand alone NVR or PC Based NVR - What are your favs?
More reading, LOL!
Seriously,..it never ends!More reading, LOL!
The main downfall for me is that the internal POE switch is not on the same subnet as the NVR so you have to manually configure your computers ip address each time you want to access your cameras directly.
Yeah I know I will possibly regret not doing BI for the start,...but I already talked to Andy and got some prices so I am going to place an order today. By the time my cameras and cable gets here and I actually run my cables, I could probably have researched the BI a little more and bought a dedicated PC and still gone that route,... but I just want hook everything up for a quick test run and get these up and installed ASAP.
Funny thing is after reading your post I was starting to contemplate BI again! LOL But my indecisiveness is starting to drive me crazy (as well as others I'm sure!),...and I just want to get this started so I am sticking to my guns. Plus if I wait then getting BI will give me something to do next winter break when my work slows down again!
But thanks to everyone for their advice and opinions, it really helped A LOT.
And be prepared cause I know I'm gonna get stuck somehow or another as soon as start configuring and setting up cams and my NVR! Especially when I try to tackle this VPN thing with my Comcast router/modem combo!But I will read through all these threads again to get a head start before I go bugging you guys, since I know there has already been some great advice given and ways to go about it. (just wish I understood it,...but I'm getting there!)
This. I know the high performance Samsung cards are often recommended.Are you going to record to an internal SD Card on the cams as well? Just wondering. If so you want to get high endurance SD cards and I've heard to stay away from Sandisk cards. If so I would install them first. Once you mount the cams it may be a PITA to install.
This one is often recommended.Yes I was planning to add SD cards. And I probably would of gotten Sandisk so thanks for the heads up! Do you have the model# for the Samsung's? every little bit of research I can avoid will help. haha
