I'm looking to set up a Reolink RLC-410 to any compatible NVR. I can connect the POE cable from the camera to the NVR, but I won't be able to connect the NVR to the router via a cable.
I am not too keen to use a wifi extender because it would probably reduce the connection speeds to the other systems in the house. If I were to use a powerline adapter by connecting the IP cams to the NVR via poe connection, then connecting the NVR to a powerline adapater, and finally connecting the router to a powerline adapter, would it provide online connectivity for the NVR and power/data connection for the cameras?
If not, what would be a solution? I really just want remote access to the NVR stream / library. I guess a wifi bridge connected to the NVR via ethernet would work better without causing speed drops for our other systems?
