- Apr 24, 2017
- 16
- 12
Thank you, I went with your advice and adjusted everything after reading the optimizing blue iris sticky. I am now averaging around 65% usage which is a lot better than before.direct to disk should help substantially....ensure you did it for each camera..HA is a setting in blue iris..there is a sticky on how to optimize blue iris, read it..
On the other hand, after adjusting the record to direct to disc option i'm getting some ghosting effects but I minimized it by increasing frame rates. On one of the cams i'm still getting it once awhile so I'm thinking about turning off direct to disc on that cam.
Also with the gDMSS lite app on my android, I have problems with it not adjusting the pan/tilt/zoom, it says "unauthorize or no permission." I know my cams are not ptz but they should at least be zoom adjustable with the app. I am able to adjust focus and pretty much everything else. Do I need the gDMSS plus version?
