I will have to eval thermal solutions prob a bit later.  For the moment I need to get some new gear running and learn from it.  To my next question, help me select the right cameras or narrow this down?  I've got several projects on my plate but today I am working on my layout.  I am currently playing with This jvsg software, which is pretty helpful in just determining my FOVs, PPF, etc.  However, I have found no listings for the rebranded Empire cams?  Is there possibly any cross reference sheets to know which Dahua cams they are?
All 54IR are 5442..
- AS are fixed overview lens (sometimes there are called -ASE) - You choose between 2.8mm (110 degrees) and 3.6mm (90)
- ZE is overview zoom - starts at 114 degrees is going to 47
- Z4E is PROPER tele photo zoom - starts at 45 and going to 15..
			In any case, I think the majority of cams would be OK at 4MP, but at least one, because I'd like it to cover a bigger area at 90* view angle, I am thinking of an 8MP for that?  I probably want to stick with vari focal cams as I am just not seasons to know precisely what I need, and want the adjustability.  If the software is leading me decent, it looks like about a 5.2mm FL on a 1.2" sensor could get down to 5ft, and stay in the recognition zone out to 50ft.  This one cam has an opportunity to monitor people and traffic at many distances between 5-50ft so I feel it would obtain some good shots between those distances.
If You want 90 view angle, look at fixed 3.6mm lenses (AS/ASE models)
2.8mm 5442/54IR gives You identify up to 20ft and recognition up to 40ft (dahua overestimated the distances in this model).
3.6mm 5442/54IR gives You identify up to 22ft and recognition up to 44ft
2.8mm 5842/58IR gives You identify up to 28ft and recognition up to 56ft
3.6mm 5842/58IR gives You identify up to 35ft and recognition up to 70ft
3.6mm gives You +25% range in comparison to 2.6mm
4K (8Mpx) gives You +50% range in comparison to 4Mpx..
the same You can have on ZE models zoomed to 90degrees horizontal FOV (but static lens models are brighter)...
3.6mm focal gives You less compressed image of people (they are bigger that on 2.8mm focal)..
Fixed 3.6mm is basic model I use most often as overview camera...
Don't look at Color4K at all - this camera model is more for fun that for real CCTV... Too limited and too many problems with them..
In very good lighting You can try to use 180 degrees cams (Color4k-B180). They are full color (no IR!!!!), they create very wide 8Mpx image from 2 sensors 4Mpx...
They work very well in middle on wall, at entrances etc..
But remember they are overview cams... and they have around 3ft half circle dead zone under camera...
			The ones pointing right at our gates/card readers are places where people would have to stop, would have to get out and engage our readers so the opportunity is good, and I feel 4MP cams will be fine for that.  But in all cases, I am mostly seeing places where I need 90* of coverage.  I am not sure if that is typically covered with a single cam?  I have strategically placed cams at specific choke points, knowing bad guys are likely to approach door openings, with various distances from the cam to hopefully get great coverage.
there are many models:
- you use mostly/only overview cams around building (90% installations are done this way), in this situation 3.6mm 90 degrees hFoV 8MPx can give You some advantage,
- you use overview cams + zoomed cams directed at strategic places,
- you use overview cams + PTZ..
- you use overview cams + zoomed + PTZ depending of the needs / area..
each model have own pluses and minuses..
			I am targeting a mount height of 10ft give or take.  For nearly all cams, I would have to attach to either a pole, or the side of a steel building so my thought is bullets?  I personally like domes better as they seem harder to destroy but I guess part of my strategy is making cams visible and obvious.  I know there are two rules of thought on that.  With domes, I also like that at a glance, you cannot tell where they are aimed.  But seems they need bottom mounted.
I am also trying to understand the models from Empire vs Dahua.  Empires are maybe not the latest revisions?  Is that software stuff?  Optics?  Sensor?
I want to stick with 1/1.8 on 4MP or 1/1.2 if we do a couple 8MP.  But to keep it simple, It appears most of our shots would be between 20-100ft.  Just saying that  I may not be able to utilize extreme focal lengths at the moment.  I think we need to get cams up and running, then evaluate the next steps.
54IR, 58IR are the same as latest Dahua 5442/5842... there is no difference..
Color4K is previous generation, latest is not available in the USA..
First, You should order each model 1 pcs and play with them..
especially higher zoom variant (Z4E) which as I understand You don't feel now (You are talking non stop about overview cams)..
Also You should try one 25x PTZ... PTZ5A4M-25X is a killer at night, but with limited budget You can try PTZ425DB-AT or SDT4E425-8P-GB-APV1 (ptz + panorama)..
Second - even with project from cctvdesigntool.com always have 20-40% more cams in different models variations on car, because when You install cam and start watching into monitor with live view, usually things pop up that the project didn't take into account.
			I get the optics.  I certainly appreciate all the help, and obviously I am just frustrated because I realize many here are in "play" mode, working with a small-ish residential lot, and we have not only the 5ac to cover, we have several buildings, plus the desire to get prelim into outside the fenced area.  And to add more, it is virtually a guarantee we will engage the bad guys.  I walked the back city owned area with a city worker 2 days ago to discover the neighbor's fence was cut open.  Our threat is real, but we can manage it because this ain't Chicago, LA, etc.
you'd be surprised but a few people who responded to you have more knowledge/experience than 90% of installers on the market...
			If I were to "cover" every point of interest, I would need 500 cams, ,and I am trying to get a grasp on how I want to do this.  I cannot hover around "ID level DORI" for every location.  Some, I simply need "trigger that IVS", in which that might invoke some extreme spot lights, sirens, and strobes, etc, etc.  A false trigger is not even a big deal there because there will be no one around the area at night!  This is not a residential area!  No one is either there to complain, or even can because we are allowed certain things by right with the zoning.
It does sound like I need to think more on the PTZ or thermal options BUT I don't even know where the threats might come from yet.  My overall intent is the scan well outside our property and alarm/trip before anything ever happens.  But I also want a glimpse of what the trigger was.  If I know it was indeed a human, solid!  I don't even care if it's law enforcement, the system did its job.
Installations of this size are always a compromise between needs and possibilities and realities.
In most cases, installations of this type are mostly overview cameras, which record images and generate events from IVS. In most cases, they do not provide the ability to identify each person everywhere.
Along with the development of the project, cameras with zoom (telezoom) are added, directed at critically selected places where there is a high chance that a burglar will pass. Alternatively, PTZ cameras, which solve the problem of choosing this place.
P.S. identification is very important, but the reality with such large installations is that it cannot be ensured everywhere. And that worst burglars will have their faces covered anyway.
