Day/Night Switch
Day/night switch here is realized by control of IR cut-off filter. Select the day/night switch mode from the drop-down list. Day, night, auto, scheduled-switch, and triggered by alarm input are selectable.
Day: the camera stays at day mode.
Night: the camera stays at night mode.
Auto: the camera switches between the day mode and the night mode according to the illumination automatically. The sensitivity ranges from 0 to 7, the higher the value is, the easier the mode switches. The filtering time refers to the time interval between the day/night switch. You can set it from 5s to 120s.
Scheduled-Switch: Set the start time and the end time to define the duration for day/night mode.
Triggered by Alarm Input: The switch is triggered by alarm input, and you can set the triggering status to day or night.
Smart Supplement Light gives user an option to turn ON/OFF the supplement light.
Set the supplement light to ON, and Auto and Manual are selectable for light mode. Select AUTO, and the supplement light changes according to the actual luminance. E.g., if the current scene is bright enough, then the supplement light adjusts itself to lower power; and if the scene is not bright enough, the light adjusts itself to higher power.
Select Manual, and you can adjust the supplement by adjusting the distance. E.g., If the object is near the camera, the device adjusts the supplement light to lower power, and the light is in higher power if the object is far away.
