you need to set the local lan port to 50000 as well.
I had him change his BI listen port to 80 so browsers on his LAN would not need a port number entered. Maybe not the wisest choice, since maybe it is easier to just remember "port 50000" regardless of where you connect from.
Anyway, @thejbgc see if you can find a DMZ section in your router. If you happen to have one of your cameras configured as the DMZ host then your current situation would make more sense.
