whoami ™
Pulling my weight
upgrading to Windows Pro to get that costs AUD170!
Windows 10 Pro is FREE... long as the Activate Windows watermark in the lower right corner doesn't bother you.
If you use the Windows media creation tool now you get v. 1903. Only thing you wouldnt be able to do with it without the key is change some display background settings. I change hardware on my computers so often I rarely ever have a activated copy of Windows.
Just click the install key later option when installing Windows. Just make sure to back up BlueIris and your Stunnel config if you have one onto a removable drive first. When you restore BlueIris your BI key will reattach its self.
If the Activate Windows watermark bothers you buy a key off ebay from one of the sellers in the EU. You can get a key for less than $10 and they email it to you immediately. Ive bought probably 10+ keys like that and never had a issue.
