Been reading a lot on here about how many of you use cameras for ID’ing after an incident. My primary use case is more so for triggering alerts when someone comes onto my property, as part of detection and early warning. Does anyone have any automatons they use in conjunction with this use case to aid in the early warning, besides the obvious phone alert (I use pushover)?
Please note: After I typed this I was unable to Post with screenshots inline. Not sure why, never happened before. I've attached files - maybe you can see them.
You are probably aware of this, but
Blue Iris includes a large number of audio files such as alarms and sirens that can be played natively
in response to triggers and alerts:
<screenshot>
My Blue Iris machine is a headless box in the server room, so don't really have any audio output from that machine. Instead, I use Blue Iris and Home Assistant
with MPD players distributed around the house. The little speaker units are fairly innocuous looking and indistinct. But the cost of and availability of
Raspberry Pi's these days makes it a little challenging.
<screenshot>
I actually have four MPD players in the house because in addition to the general purpose ones for Blue Iris and Home Assistant, I also have high quality
Digital to Analog (DAC) audio hats for the Pi's that are attached to vintage stereos and use MPD based jukebox software called Rune Audio. Home Assistant
sees those as media players too.
<screenshot>
Having said that, we have a lot of redundant and not particularly well thought out functionality in our house. For example Home Assistant supports Text-to-speech (TTS) on
MPD devices, so they are often used in my house as intercoms (fun to hear, "Somebody bring me a beer!" on my my 40-year Sansui or Mitsubishi stereos
), but we also
have Dahua VTH's that we use for intercoms, and wall mounted touchscreen PC's that are used with SIP as intercoms. Home Assistant can also control various networked
audio receivers (we have a Yamaha, for example) and those can be used in automations. others have mentioned, once home automation software and MQTT are
integrated, basically the sky's the limit on what you can do with audio, lights, etc.
Although these days I primarily pass triggers and alerts to Home Assistant via MQTT, you can access MPD through the Blue Iris machine without Home Assistant:
I wrote a little blurb about it at one point:
Thank you everyone! I have received so much from this community, and I am very appreciative of all the insight and knowledge (hard won sometimes, I can tell). I wanted to contribute something, perhaps trivial, and only one of many ways to skin the cat, but I find it useful and am hoping that...
ipcamtalk.com
