Good morning!
This is how the cameras are currently set it, they are pointed to the cameras NIC.
I tried running the NTP checker on another computer (off the server) on our LAN and it was a no-go. BUT on the same computer, if I enter the main LAN NIC, it works! Is it safe (hacking-wise and cameras being able to reach the internet) to point the camera's NTP to the main LAN NIC and not the camera NIC?
I'm not a Windows or NetTime app user, but does NetTime's time server need to be bound to the camera network NIC to listen on that NIC instead of the main LAN NIC?
Sorry, I forgot to tell you to try that program from a machine other than your NTP server. You want to see if you can get through to the server from the network/cams.
Load it up on another machine. Point it to your NetTime server. Click Test like 5 or 6 times. On the server, open the NetTime log. You should see the connections from that machine at the bottom of the log.
Nothing unusual that I can think of as far as this goes for the Dahua cams.
