Mast Diameter | ɸ 80~1 5 0mm ɸ 3.15 ””~5.91 |
Oh dang I thought it went smaller.
You could always go buy the ring at a local hardware store to fit the size you need and then replace these rings thru the bracket.
Yep, hose clamp escaped me for a moment LOL. I had to replace them on this bracket to make it longer.
