Plugged USB stick to NVR and mounted.
mount /dev/msb /mnt/esda1
But i cannot execute any command from mounted USB stick.
[root@dvrdvs sbin] # ls
badblocks flash_otp_write mklost+found rfddump
blkid flash_unlock mtd5ro.test rfdformat
debugfs flashcp mtd6dump90 serve_image
doc_loadbios fsck mtd6dump91 sumtool
docfdisk fsck.ext2 mtd6ro.test tune2fs
dumpe2fs fsck.ext3 mtd_debug ubiattach
e2freefrag fsck.ext4 mtdinfo ubiblock
e2fsck fsck.ext4dev mtdro5.nand ubicrc32
e2image ftl_check mtdro6.nand ubidetach
e2label ftl_format mtdro6.nand.bak ubiformat
e2undo jffs2dump nand5 ubimkvol
e4defrag jffs2reader nand5rox ubinfo
filefrag logsave nand6.after ubinize
findfs mke2fs nanddump ubirename
flash_erase mkfs.ext2 nandtest ubirmvol
flash_eraseall mkfs.ext3 nandwrite ubirsvol
flash_lock mkfs.ext4 nftl_format ubiupdatevol
flash_otp_dump mkfs.ext4dev nftldump uuidd
flash_otp_info mkfs.jffs2 recv_image
flash_otp_lock mkfs.ubifs resize2fs
[root@dvrdvs sbin] # pwd
/mnt/esda1/mtd/mtdutils-1.5.0-arm-linux-gnueabi/sbin
[root@dvrdvs sbin] # ./flash_erase
-sh: ./flash_erase: not found
