andrewy
If you can ask for the model number I would check to see if there are any firmware updates available for it. Power supply is another concern but usually you can find replacement ones dirt cheap.
Also when you get it do a factory reset on it, don't use any default passwords or passwords that are provided with the NVR.
Here's the firmware search tool
www.dahuasecurity.com
Dahua Technology - World-leading Video-centric AIoT Solution and Service Provide
Dahua Technology
