- Sep 13, 2015
- 776
- 241
OK...shot in the dark: the transition from day to night means the camera IR lights up, correct? When this happens the camera draws more power. Just a guess but when the day to night transition occurs the camera may need to refocus to adjust to the lighting change. The refocus also drains power. Therefore, maybe, just maybe, the power being supplied to the camera at this precise point in time (IR lights and camera refocuses) is insufficient. How are you powering this camera? And do you have any alternative method to power the camera to disprove my theory? I'd suggest that you buy one of those TrendNet PoE+ adapters and see if that solves the issue.
Hey, did I ever tell you how they may have faked the moon landings?
I'm powering with a dedicated power supply which is more than enough to power the camera properly
I had issue with power on Poe so run a proper dedicated supply.
So I'm confident it isn't a power issue itself
(Although I'm not saying I am 100% right)
