no problem, it's weatherproof camera, just protect the cable connector well. Maybe add a junction box PFA139.
I am wanting to replace a Lorex E581CBB for interior use, what do you suggest? It is mounted above a kitchen cabinet and I feel a turret would be out of place. I have been more than happy with my IPC-T5442TM-AS and am considering using one of those but, again, it may look out of place in the kitchen.
I like the idea of the dome, but is there a similar bullet option?Use this 2mp one, cheaper and good enough for using in kitchen.
Send an email to [email protected]Guess I was a tad late.... I need to buy 7 of the IPC-T5442T-ZE. Anyway to get a bulk discount?
Not the correct bracket. But It's aluminum, so it would be easy enough to drill and tap what ever holes you need.@EMPIRETECANDY
Received the PFB203W wall bracket today but I can't seen to line up the mounting holes for the SD1A203T-GN bracket.
Is this the wrong wall mount or am I just that dense?![]()
See the correct brackets here
Any amount.How much do you have to spend to get bulk discount?
The PFB203W is not work with this mini ptz, just guys here found this trick, can make the installation easily and looks good!Thanks Brad, this is the one that was paired on Andy's Amazon page so I thought it would be good. I will drill and tap to make work, much better looking than the other setup.
