fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,415
Once again posting false and misleading information. First, its clear that you are not a "technologist" since its self evident in your past posts that you have little to no technical skill.Ignore Fendermans rants. While he has good knowledge of BI software, he just likes to argue.
By his own statement... If your server ran at 300w 24hrs a day, the yearly kWh is 2656. At 11 cents per kWh (most people pay 9 cents)... The electricity cost is 295/yr.
Of course, he assumes what your server draw is. He has no real data about the system... And neither do I. We have completely imaginary cost of your electricity to run your system.
You could look it up but many systems ran very efficiently for thier time. I've seen older system as low as 65w at mid power and up to 200 when loaded with a decent amt memory and old hdds. Rule of thumb is take your power supply max rating and 30% of that is the norm for a moderate sold configuration
Btw, you might want to pull out a cpu and back down to 16gb ram. The rest is unnecessary for only BI
... But don't take my word for it. Looks up your specs if you want to know for sure.
HP published all those in quickspecs. Dell did to, but often harder to find.
... Btw, I could be full of it or maybe my years as an engineer, consultant, and product design, at Microsoft, Dell and HP (chief Technologist) has given me experience in this area. I'll let you decide if I can be trusted
Sent from my SM-G935T using Tapatalk
Second, "most people" DONT bay 9 cents a kwh..the most heavly populated states, california, new york, new jersey etc have the highest rates. With taxes delivery and fees you are looking at at least 20 cents. Even if the system only drew 200w at load you are looking at 349 for the year...hell you can buy a used i5-4590 system for about 200 bux.
I guess when you stated that "you will not benefit from it and your power consumption will only save you $10/year. 30 year payback " you were using your skills as an engineer to come up with those numbers....
I have tested many of these machines on a killawatt meter and I can tell you that you have ZERO clue. So much so that I am confident that you are lying about your credentials.
