Yes this is during live vie and the motherboard only has VGA.VGA vs DVI is probably where the quality drop is. Does the motherboard only have VGA out?
Not sure why running off the AMD card drops the CPU. Is this during live view with the BI program open?
When you said 'you forgot that bit' what was each cam set to for hardware decode? Or did you forget to restart?
Hardware decode was set to no. I did restart after setting Hardware Accerlated decode.
