Sorry. It is just 2, 2mp cameras. Good WiFi setup. Wouldn’t think it would be taxing it, but will test with wire.wifi is likely the cause of this and should have been mentioned first. You are feeding multiple cameras over wifi to the machine..packets will drop.
EDIT: I tested using Windows Remote Connection and was able to connect. Cameras are POE. If I plug my BI PC via ethernet to my router, but then remotely connect to the BI PC via remote connection, could that also cause the video stuttering (i.e. - just viewing the clips over wifi)? If so, I'll move my monitor over for a few days to test as well.
