Yes, if I'm watching the same live-stream camera on both phone and PC, both on the same network, I get identical data on the stats window.
Is the variability of the bitrate waveform normal for an image which is showing no perceptible change in video content?
Every one of my cameras is using sub-streams.  And all are set to use same frame and i-frame.   Most are set to 15 / 15.   Is there a global way to disable sub-streams or would i have to go into each camera to disable it one at at time?
Thing is, I didn't have nearly this amount of jerkiness when running on 5.5.0.15 - and I can revert back to it and I'm smooth.  That's really what makes me think there is some kind of incompatibility with my hardware and the whatever changed since that version.
My server is running without a physical monitor (headless) and I'm using VNC to make changes on it.  That has some inherent video latency, so I cannot really confirm whether the console has the same jerkiness - at least not without climbing into my network closet and put a monitor on the PC.   I'll do it, but only after exhausting some of the easier items on the differential.
As for my stream 0 configuration under the web server options, here's what I currently have setup:
Wasn't quite sure where you meant for me to do the non-VBR.  I assume in the UI3 interface?   I just tried it for 4k on both phone and PC, and both continued the same behavior.
If I haven't said it enough, I really appreciate your interest in getting me squared away.  I miss the days where reviewing an event on BI was fun.  Now it's so frustrating to find things...
Fortunately when I export everything is smooth as butter.
Hey, BTW, do you know of a way to cancel a queued export?  I posted separately on this but no takers.   I accidentally started an export on my phone via UI3 - my fat finger hit export when I was trying to click the timelapse checkbox... and it was before used the red and green trim handles to get it down to what I wanted - and so it dutifully put it in the queue - all 8 hours worth.
