The router typically assigns or manages the IP address traffic.  A "dumb" switch is no different than simply having more ports on your router - the whole purpose of the switch is to provide additional wired ports.
So your cameras are probably on the same IP addresses range of your other devices and thus the cameras are probably passing through the router (you won't know for sure unless you monitor it). Maybe it is and maybe it isn't. But if you login in the admin screen of the router, you will see the cameras as devices on the router, so the potential is certainly there for it to be passing through it.
But unless you have taken steps to keep them from being able to talk to the outside world, they are either phoning home or open to being hacked. Ironically surveillance cameras are known to be very poor at security. They need to be isolated from the Internet via VLAN or a dual NIC system.
In a dual NIC or VLAN system, the router never sees the camera IP addresses. They do not exist according to the router.
